Glesser, Fikes, Koster, Dale, Sugai, Lee, Stanley, and Carter all make sharpening videos.
I want to confirm specifically that you have the belt sander turned on.
Try Trizact belts. Most 1X30 belts are made for sanding wood. They will not last on metal.
LOL! That might explain it! I have several other questions, though:
Is the belt new or worn?
Is the belt open-coat (made for wood) or closed-coat (made for metal)?
Does your machine stall if you press the blade to the belt with any force?
Are you so afraid you'll overheat the blade you don't dare press it to the belt with any force?
Generally, I don't press hard because it skips on the platen or rounds the edge when I don't use the platen.
