Hmm, I think you have something there brownshoe, but I also think speeding up the "break in" of the knife by repeatedly rubbing the tang and spring together with little or no lubricant will rub off high spots, and fit or bed the pieces together, which should ease the effort of opening the blade. If it's all about wearing the spring in to slightly weaken it, then leaving the knife open where the spring is "sprung" the most should be the answer. Interestingly, I left a couple of 45ACP clips fully loaded for 10-11 years! (I know, firearm abuse!). But I couldn't detect any spring weakness when I found them finally, and tested them out. Worked perfectly and took a lot of pressure to reload them.
The effectiveness of any of this will depend on how well the blade and spring are made, and matched in temper.
