Extreme Lightweight Hiking Kit-Modern Nessmuk
Anyone who has ever hiked/camped with me knows how extreme I am when it comes to backpacking/hiking/camp gear weight. For years I have modified existing gear and then eventually started making my own quilts and beanie’s.
Bag
My usual Daypack is a Gossamer Gear RikSak (2 ounces). I keep my 2L Platty in there, a small folding saw, a light cook-can, gloves, and food/snacks.
Cook gear
I use either a Fosters Beer can or small size Heineken Beer can for boiling water for making rice or mashed potatoes, and coffee. The Fosters is rigid compared to regular soda cans. I use a Goodcook safety can opener to remove the top without leaving any sharp edges, and it also makes a perfect pot lid. The weight on my old MSR Titan Titanium kettle was 4 ounces with lid. The Fosters is about .5 ounces (with lid). I used a hole puncher and added a wire hanger as a bale. The smallest boiler I use is a Heineken, which is hard to get a reading on the weight because it doesn’t register much. When the top is removed with a safety can opener it leaves the ring at the top intact, making it rigid for use as a cup. When full, it’s enough water to rehydrate packaged rice, mashed potatoes or pasta. Extreme lightness is achieved by using either one and is usually just the right amount of water capacity.
Super Cat Alcohol Stove is used when I am not going to have an open fire or just want a quick boil for coffee or rice. It is a Fancy Feast cat food can, with about 16n holes punched in the top. I use denatured alcohol as fuel, but many other types will work. Lots of backpackers use HEET. It weighs.25 ounces and holds about 1 ounce of fuel, which will boil water super-fast. It burns out clean and dry. If I am going to have an open fire, I forgo the Super Cat.
Food-Craft
Small fire can be done by gathering sticks, not necessarily chopping everything.
The fuzz sticks are mimicking the natural tinder on the right (poplar bark) so they need to be thin enough to catch a spark.
I’m from the Mors Kochanski school of thought—having at least three good fuzz sticks nearby as kindling or for use as tinder before making a fire.
Light Food ideas that only need water…
Cut package sideways to make it easier to eat.
The split wood pegs will clamp the package closed to keep in the heat while it rehydrates the rice. Light batoning with the knife after sawing the green wood was all it took for this little trick. It can also be used to secure tarps, plastic and space blankets to a ridgeline.
Support bar with variable notches can be easily done with a small knife or saw
Having spent a lot of time over the last 8 years in Asia, I used chopsticks a lot. Last year, in Japan I used chopsticks for one month straight and didn’t even have the option of a spoon or fork. It makes sense though; bamboo chopsticks are lighter than any titanium spoon out there. They are the simplest way to eat, short of using your hands. Food can be picked up or poked with chopsticks.
Ultralight Tools
For quick day hikes I don’t do much chopping for two reasons:
-It saves weight not bringing a chopping tool (axe/hawk/ hatchet/machete) while hiking
-There’s already an abundance of wood, so I don’t need to chop
Every size stick needed for a fire is here…everywhere. Where is the need to chop?
Most everything I have ever done in survival classes and camping requires wood from pencil lead thickness, pencil thickness, finger thickness, and then up to wrist size. A small saw can easily handle that task. Anything thicker is fuel and can get thrown on as is. I like to use an old Fiskars (made in Finland) saw that has a 7” blade and is retractable. I’ve had it for about 10 years and it is the lightest saw I have ever seen in that size. Also, it was $10 in 2005. I use a knife for food prep, cutting green and dry sticks for making stakes to anchor down support poles used to suspend pots and roasting sticks. Trap notches (fun camp-craft activity) and fire preparation can all be done with a thin, light, super sharp blade, and done even better than using a thick beveled blade. I cross-grain baton green wood for pot hooks and trap parts, but usually on wood that is no thicker than a broom stick. This is not considered heavy-use, but practical-use. I don’t do a lot of wood batoning and most woodsmen I know don’t do it either. They just use smaller diameter sticks in a fire until they can burn the larger pieces. Unless I am sleeping next to a long-fire, I don’t use big logs, just broomstick-thick up to wrist thickness. All this can be done with a rat tail/stick tang knife easily. Truthfully, most wood found in the forest can be easily processed with hands and feet, so work gloves are always good to have.
I always have a SAK Hiker or Huntsman (on long travel trips) as my base gear.
Possibles Pouch
Most of my important gear is in the possibles pouch. I hate things in my pockets. Having them in a pouch means I can set my pack down and scout around knowing I have all my important gear on me. When backpacking, it is way easier to take one thing off at night before turning in. It has all my necessary things for fire, flashlight, water purification, and signaling.
Wine Berry
Still not ready yet.
Another great post, thank you. I saw most of it over at B&B.
Like to go hiking with you some time. Think we would get along.
I use chopsticks also, I have a GSI kung foon but usually just make a pair at camp, gives the boy scouts something to talk about.
I prefer my BK11 to my Mora, but love my Fiskers saw & x7 hatchet.
Very cool to see your setup. For years I have thought I could not backpack due to a back injury limiting how much I can carry, it just occurred to me very recently that there is an abundance of ways to pack with ultralight gear, so I appreciate seeing peoples light setups.
Nice gear, like-minded.
BK11 is a great piece of kit for sure.
Yes sir. Ultralight and super-ultralight will have you down to 5 pounds of gear (base weight). Feel free to ask me about super-light gear, not the expensive type, but the practical stuff.
-RB
I agree about fire prep, most of the time in most environments batoning is not needed. I generally take my Mora Classic 1 and a cheap 4 oz folding saw from Japan. I find that is more than enough for me to enjoy some time in the outdoors. I just posted about this combo in another thread as a matter of fact.
I wouldn't mind seeing more info about the rest of your kit as I'm working on lightening my own load. Perhaps not to the same extrme, but ideas are always welcome.
Nice setup, mora with the saw must be a great combo
Can you share the link to the other thread you mentioned?
My regular backpacking gear weight for most seasons is under 4 pounds (base gear/no food water or consumables).
-RB
I posted about it in a recent thread asking if a folding saw was worth carrying in the woods. I didn't give any additional information about the saw or knife there.
The saw is a Japanese Senkichi Nokogiri Folding Saw, it was about $12 I believe. It is a thin and light pull cut saw with a simple lock mechanism. So far I've found it to be the best saw for the weight / cost for my uses. I've had it about a year or less I would guess. It's been on a few trips with me and has performed well enough.
The knife is just a run of the mill Mora Classic #1 that I have not for the life of me been able to stop using for the last 5+ years. It's been on all of my recent trips and seen a vast amount of use and abuse. The sheath has had the blet loop removed and a paracord lanyard attached via clove hitch and diamond knot (yes I wish to be straggled to death by a tree branch in the woods).
My sleeping bag and pack weight more than your base weight but they are at least on the decline. I recently upgraded to a sub 2 lbs 40 degree bag which for me is adequate. Perhaps some day I will move to a DIY quilt, though lack of skills and a sewing machine are keeping me from going that route currently.
Do you happen to have a thread or video showing your load out? Quilt, shelter, backpack and so on?
Ultralight
(this is what I travel with then I am flying and have a major weight limitation)
I carry the Opinel Folding saw for an ultralight light and very sharp saw
It goes well with an Opinel #7 in a $1 nylon belt pouch
A Mora 2/0 is also an option, which I can carry on my belt or as a necker in a #4 Dangler sheath from Battle Horse knives
Then a SAK Tourist and a Classic lanyarded together in my emergency kit
(Don't ask my why, but I cannot have a SAK without a corkscrew :( )
Ultralight
That's a lot of sharp things.
-RB
not really
A folding saw
a fixed blade
Pocket knife and a first aid sterile knife
I'm curious about what you will do with your sterile blade?
Best to cover or duct tape an injury until getting to primary care than start cutting yourself? But my surgical skills are rusty😀?
-RB
-RB
What I carry as 'sterile' is a SAK Classic that I know is clean and no grunge
This is for maintenance not injury
Thistles, thorns and splinters
Cutting nails and toe nails
Cutting dressings
I second an small SAK in your FAK.
The scissors of my Hunstman were once used on me to drain an abscess in my left hand thumb.
I was in a multi day hiking trip and the day before I got burned by hot glue while installing a mirror in my daughter's bathroom, dumb accident that didn't seem like a big deal at the time. Long story short the burn became infected and by the second day it started to get hot, red and painful, that second night I could not sleep because of the pain and became worried as the infection was in a sensitive part and close to the bone.
The next morning with the help of one of my hiking friends, she is a nurse that hasn't practiced since forever but still the resident doc of the group, we got the scissors disinfected with several alcohol pads and she proceeded to cut into the abscess and drain it. Little pain but huge relief. This little procedure helped me complete the trip without much problem and with a cool little story to share.
Is not like this was major surgery, or that the SAK saved my thumb, but if she hadn't do that we would have cut our trip short and I would have walked back home in a lot of pain and looking for the doctor's office.
Since then I always carry a Vic Classic in my FAK to keep it clean and only to be used for fist aid.
Best Regards
