The problem my boss is having is them starting to rust while still on hunt.Lots: 12C27, VG-10, S30VS35Vn, CTS-XHP, 420HC, CM-154/CPM-154, for a start. But if you're using it, I wouldn't worry overmuch about even high carbon steel blades. Just put 'em away dry.
I've been leaning towards S30V or M390 to make his fromI have made knives for folks that big game hunt in Spain and Africa as well as the Pacific Northwest. The steels that have been used and hold up just fine with minimal rust are AEBL, 20CV (M390), S90V and S110V. AEBL takes a very keen edge but will not hold it as well as the others against abrasive materials (such as grit engrained Moose hide).
With proper care non-stainless works fine in a moderately wet environment as well.
Open to any and all suggestions as I am new to knife making. I do have a titanium coated blade coming right now.If you get a coated blade, then rust becomes a non-issue and you have a larger pool of steels to select from.
I have heard of this also, but since most of our hunting is done in 30-40 degree weather it shouldn't be an issue. But thanksAnother thing to think about is the cold weather and different types of steel. Some types they say if they get cold enough the steel will get brittle and snap possibly. While I've never had that problem I have heard/read about this problem over the years. So you may want to think about that also. Here's a link from the past on cold weather and knives.
https://www.bladeforums.com/threads/which-type-of-steel-will-work-best-in-extreme-cold-
