- Jan 6, 2009
They are two camps out there when it comes to sharpening. (Well, actually there are a couple hundred thousand camps, but I'm only dealing with two here)
One camp is: if you go to say 600 - 1000 grit equivelent on a stone, belt, sandpaper, ceramic, or what have you, and finish up on a strop, that's as good as it gets, any further polishing is a waste of time.
The other camp, particularily with super steels, is: the more you polish and refine your edge, the better the edge holding and cutting performance. I have read of some folks taking their edges to 12000 grit equivelent.
To date I've been in camp one. I usually sharpen/polish on a belt sander to 9 micron (approx. 1000 - 1200 grit) then strop on black then green compound. I get my knives shaving sharp, and they hold a very sharp working edge for a long time. In other words, nothing really wrong with what I'm doing now.
I'm not certain what grit/micron the green compound is, any searches I've done are inconclusive, other than to suggest there is likely a wide variance, anywhere from 3 to 15 microns, depending on manufacturer.
I have been wanting to try polishing to a higher level just to find out for myself if there is any advantage, but wasn't having any success finding belts any finer than 9 micron.
I contacted ECON Abrasives out of Texas a couple days ago and got a reply back today. They don't stock, but can supply, belts up to 12000 grit.
The response is below, anyone interested in very fine grit belts can contact them if interested.
Or, if you know of other suppliers, let us know who they are.
Kevin
NOTE: I only inquired about 1x42 belts, but I'm certain other sizes would be available.
Kevin , Thank you for the inquiry. We go to 9 micron, equivalent to 1000 grit, we make these in house. We can supply 1x42 belts in grit sizes;
1500
1800
2400
3200
3600
4000
6000
8000
12000
Minimum order is 6 belts per grit , and delivery would be approx. 10-14 days.
Price per belt in any of the above grits is $3.40ea. Please let me know if I can
help you. Thank you again.
Kevin
1500
1800
2400
3200
3600
4000
6000
8000
12000
