Eyelets spliting
I am fairly new to working with kydex and am haveing a real problem with my eyelets splitting when crimping them I am using a press from knifekits.com. Any help would be awesome.
I've got no experience with that problem and I haven't seen it but just to be sure..... are you mounting the finished end of the rivet on the bottom flange (no spike) and then letting the "spiked" end to flare the unfinished end of the eyelet? (eyelet not rivet) Basically you should be laying the finished end face down and the unfinished end would be face up.....
Thats the way Ive been doing it I even tried the other way just to make sure but it still it splitting the end as it rolls it.
I'm trying to be helpful but again I've got no experience with that happening.... the only problem I've ever had with eyelets is when i was first starting out I pressed them while the kydex was still warm... no good, they press right into the kydex (recess). More thoughts on your problem:
I'd try to narrow it down to one of two areas being the "problem child"...it's either your eyelets or your dies.
1. Try a couple more and see if they don't crack in the exact place meaning if the firs one cracks at 2:00 and the next one splits in the exact same place.... maybe it's your die. If it splits in a different place then maybe it's your rivets.
2. Eyelets come in several sizes... are you working with .060 kydex and using larger eyelets? If so they'll over extend and start rolling down on themselves... just check and make sure you have the right combo. I switch eyelet lengths depending on the "combined" thickness of my kydex... example... when joining two pieces of .080 eyelets required are about 1/4"..... joining two pieces of .093 you'll need a eyelet length of about 5/16".
Hope this helps, if all else fails call Knifekits and let them know what's happening. I remember how disapointed I was when I got one of those eyelet presses and found out that all they did was drill a sloppy hole in the bottom plate.... the plate just sits there... no real "machining" was done.... no exact science just a cheap-ass Harbor Freight 1/2 ton press with a hole drilled completely out of center and in no precise fashion.... sorry, it's late.
Godspeed,
Eli
I have had that problem before with dies and eyelets from Knifekits, gave them a call and found out they had some out of spec dies that got out. They fixed me up with some new dies and haven't had a problem since.
Hey thanks a lot guys I will give knife kits a call today and godspeed your right there is no real precision in the press I thought is be slick and make a stud for the hole on the bottom of the plate to keep it from sliding around....... Yeah that didn't go so well when I reinstalled it the dies were off each other about 1/4" . Thanks again for the help!
