EZE Sharpener and flat-grind Steel Hearts
Anyone have experience correcting or shimming the flat grind Steel Heart in the EZE Sharp blade clamp? I'm leery of the angle change, and need to see how others may have compensated.
Thanks!
Am I the only piglet that uses his Busse? Or the only little pig that uses the EZE Sharpener with the flat grinds? ;)
Bump...
The only one? I only regret I can't help you with the EZE. I worked four hours changing the bevel on my Heavy Heart with a Lansky. My Heavy Heart is now one of the most dangerous things I own. ;)
Thanks!
I think I'd do fine with the Heavy Heart, it has a sabre grind that gives me a shoulder to work with (flat surface to clamp on). These flat ground blades introduce another variable...
