Fällkniven WM1, kydex
<A HREF="http://www.canit.se/%7Egriffon/knives/fallkniven/wm1c.jpg"><IMG ALIGN=RIGHT SRC="http://www.canit.se/%7Egriffon/knives/fallkniven/_wm1c.jpg"></A>
This week I got a new WM1, with the new kydex sheath, and I'm very satisfied with it. Easy to carry, easy to take out of the sheath and put back.
<A HREF="http://www.canit.se/%7Egriffon/knives/fallkniven/wm1d.jpg"><IMG ALIGN=LEFT SRC="http://www.canit.se/%7Egriffon/knives/fallkniven/_wm1d.jpg"></A>
The knife itself is the same good knife. Convex grind, rolled edge, 3.5 mm wide near the handle and tapering all the way towards the point, balance point about 30 mm in from the guard.
It's of course designed with small hands in mind, but that's not all of it, as then a scaled down "mini-F1" would have done the job (but not really being necessary, as the F1 itself is very suitable to different hand sizes, as is the WM1). To my mind, it's more sort of a smaller, modernized, knife of a slightly different kind than the A1/S1/F1, as shown by the different handle profile.
<BR CLEAR=RIGHT><A HREF="http://www.canit.se/%7Egriffon/knives/fallkniven/wm1a.jpg"><IMG ALIGN=RIGHT SRC="http://www.canit.se/%7Egriffon/knives/fallkniven/_wm1a.jpg"></A>
The kydex sheath holds the knife very securely, even without the strap. I'd trust it for upside down carry that way.
The belt loop is wide enough for wide belts.
Construction is very sturdy, without feeling heavy nor big.
Sometimes I like a leather dangler sheath better, for example with a backpack, but for the most part I think I prefer this style.
The kydex sheaths can be had separately: http://www.fallkniven.se/kydex.htm
More about the knife: http://www.fallkniven.se/wm.htm
Urban Fredriksson
"Smooth and serrated blades cut in two entirely different fashions."
- The Teeth of the Tyrannosaurs, Scientific American, Sep 1999
[This message has been edited by Griffon (edited 19 November 1999).]
Griffon: Are these Kydex sheaths available in the US yet? From whom? I, too, would like a WM in a Kydex sheath. For that matter, I'd like a Kydex for my F1.
Hi Griffon,
Does that nylon belt loop have the option of being removed. I like this this knife alot. Even better with a kydex or concealex multicarry sheath.
Will the price remain about the same with the kydex?
sing
AKTI #A000356
PS. I just noticed the sheath is missing an additional hole for ball chain/neck carry. Is there room for drilling a hole. Looks tight with the blade form extending almost to the edge of the sheath.
[This message has been edited by sing (edited 19 November 1999).]
I don't know about availability, but considering how short time they've been available here, I doubt they've made it across the Atlantic yet.
The nylon loop is riveted, as is the retaining strap.
There certainly isn't room enough for another hole the same size as the existing ones. A smaller one might fit, but then you'd have to drill very close to the edge where the kydex is bent 180 deg, and I'm not sure that's a good idea?
The Fällkniven knives cost more with kydex sheaths. How much more, in USD, I couldn't say.
Urban Fredriksson
I just got some information on Fallkniven's kydex sheaths, as sold separately. I haven't done all the math yet, but they'll probably go for about $30+/-, and probably add about $15+/- to the price of the knives with Kydex alone, except for the A1, where the difference will be more like $10.
As of last night, they're not in North America yet.
- JKM
www.chaicutlery.com
AKTI Member # SA00001
And a question, since I haven't seen the sheaths up close yet -
Is the belt loop held on by screws or rivets? If it's removable, then the WM can be a non-folding pocket knife, or worn as a neck-knife, handle-up.
- JKM
www.chaicutlery.com
James,
Griffon's posted above that the nylon loop is riveted. Also, the bottom of the sheath lacks two holes for a neck chain and may not have room for those looking to put a hole in themselves.
sing
AKTI #A000356
Griffon,
1. What is the handle material?
2. Nice post. How do you link thumbnails which are clickable? I can see the codes using the edit function, but that does not help me to understand without some explanation, especially since some things that use to require codes not translate automatically into links, etc. I like this idea because it keeps the thread fast, yet provides a hint of the image. This is important because even if one has a fast connection (I do), which everone does not, the server where the picture is can still slow down the loading of the post--at least the picture part. In short can I do this with PhotoPoint or do I need an actual webpage? [This thread seems to be fairly complete but if the answer is long and you do not want to make the thread too long, I would be happy with a new thread started in the help forum.]
Thanks.
Donald.
I just received an email from Fallkniven that just this week they sent a shipment of kydex sheaths to the US to Blue Ridge Knives and it should be here in a week or so.
I'm not sure but does BRK only sell to dealers?
Hoodoo
In all affairs it's a healthy thing now and then to hang a question mark on the things you have long taken for granted.
--Bertrand Russell
I don't know what the handle material Thermorun E is, exactly, but it's some kind of strong, slightly resilient plastic. It's not like rubber, which has advantages for me I go into in <A HREF="http://www.bladeforums.com/ubb/Forum32/HTML/001275.html">another thread</A>.
I think I've forgotten to point out how very lightweight it is: My WM1 only weighs 70 g, which is very lightweight indeed!. <small>(About 2.5 oz, if I've done the numbers right.)</small> With the kydex sheat it only comes to 123 g <small>(4.4 oz)</small>.
How to do small thumbnails is a bit hard to explain, because you can't write the code itself here, as it turns into an image and link.
What you have to do is to put two versions of the images on your web site, a small and a large. Then you link to the big image and instead of link text put in a image reference to the small image.
Urban Fredriksson
A clever fellow could put a neck cord through the existing hole near the tip and tie a hitch around the sheath so it'll hang straight.
I prefer a pocket sheath to be a true slip sheath with no retention, but YMMV.
-Cougar Allen :{)
Hi Guys...
I wonder why they used rivets instead of chicago screws...?
This setup would make the knife near useless as a neck knife...
I prefer a ridgid belt loop on this size of knife. The belt loop can be moved around or removed for true multi carry use.
The Fall rig could be lashed to LBE gear upside down with this type of setup...
Still don't understand why a snap is used though! I put snaps or buckles on,,but they are Always removable...
Looks fairly funtional though.. Very Nice Blade!!
ttyle Eric - On/Scene
Eric E. Noeldechen
On/Scene Tactical
http://www.mnsi.net/~nbtnoel
Cost? It's already noticable more expensive than the leather sheath.
And it's not intended as such either, but rather like the new "standard" sheath.
Some customers are conservative.
Urban Fredriksson
Hi...
I didn't mean neck knife,,sorry,, but rather to use it upside down on LBE gear..
As far as cost,, and extra .40 cents wouldn't bother me none!
ttyle Eric...
Eric E. Noeldechen
On/Scene Tactical
