Thank for the info, but I was already aware that Carpenter used to make it, and if I had enough money to order 30,000 pounds, I could order it from just about anybody.Lots of luck....
In 1975 or so, I got a couple of pieces from a Carpenter rep
in Saint Louis. They were extra from a mill run. Since then I've
not been able to find any.
BUT...They will make it for you, if you order 30,000 pounds.
I've seen the chart and found nothing. I can't find a Euro standard but there might be one. O7 is slightly easier to find but F2 is basically non-existant. I've basically exhausted commercial sources and I'm just looking for someone that might still have some. I'm not really looking for a regular source.Larrin, have you seen this manufacturer cross reference chart?
http://www.varcoprecision.com/tools.htm
Also, have you cross referenced the analysis against Euro standards to see if there's an equivalent? I was sort of surprised the other day when Achim said the domestically uncommon O2 was readily available in Germany.
Just a couple thoughts of where you may find a lead....
I actually have some, that's the closest I have right now. It's double the tungsten of F2, and WAY more than O7. As a side note, since the steel he ordered is supposed to be much closer to O7, I have a suspicion that the spectro-analysis (not sure of the spelling) was off. According to Dick Barber, those things have to calibrated correctly for different types of steels.Right now, Chuck Bybee has a supply of a steel which is a modification
of O7.
Roughly 1 % carbon, 6 % tungsten, .18 Vanadium, 1.5 % Chrome,
and .4 Manganese.
He's at Alpha Knife Supply.
It's V-Toku1 that I'm trying to get. It looks like I'll have to buy at least 200 kg, and I'm trying to get it in the thinnest size possible so I can use it in damascus, but it's taken more than one e-mail because of problems in translattion, so I still don't know if I can get it or not.If you figure out a way to order some of the V special 1 (???) from Takefu, let me know - I've been contemplating trying to get some myself. FWIW - several japanese planemakers use some old F2/O7 like steels with 1.3%C, 1.4%Cr and 6.5%W and another with 1.3%C, 0.7%Cr and 5.6%W which would be in the same ballpark as the numbers posted above. Assuming the numbers for Chuck's steel are accurate.
Thank you, I wondered what Toku meant. They definitely seem as though they would sell to the U.S. if they like the order. Not near as easy as Crucible of course. It does make me wonder why a supplier doesn't attempt to get VG-10 for sale though.Yep - "Toku" translates as "special" - my attempt to paste in the kanji came out as (???).
I'd be after 2.5-3mm thickness, different than what you want. If your transaction works out I'll at least know it's possible.I'd have the same translation problems. Good luck.
And how do I get my hands on some 1.2519? That's actually one of the designations that I was searching for. The only company I found it in was Bestar and they said that they don't have any on hand and that there is a very large minimum order.Larrin, what i use in my damascus and what we also used in the big block was german 1.2519. This is a steel with 1.1 % C, 1.2 % Cr, 0.2 % V and 1.3 % W (tungsten). In "my" steel mill they make sheets down to 1.5 mm thickness of this steel.
If i would like to have a steel i could not find on the market, i would just melt it on my own and forge it down to the needed size. At least up to 40 pounds this is not a big problem.
Achim
I e-mailed you back, but kept getting a "message rejected" message back. I sent it to your wirtz at 7knifedwarfs.com address instead.Larrin, mail sent.
