- Aug 9, 2021
Here are the first 50 or so blades, in decreasing order of inclusive bevel angle. Also listed are the angles for the left and right sides in degrees. The measurements are probably accurate to about a degree. I measured some of the blades with two different Gritomatic laser goniometers, the cheaper one and the one with magnets. They agreed to within a degree, with the differences probably due to my inability to get the blade positioned exactly right.
An entry such as (14,33) means that the bevel is convex, ranging from 14 degrees towards the spine to 33 degrees near the apex.
An entry such as (18,40+) means that the angle near the apex is bigger than I can read off the goniometer. A very wide angle like this does not necessarily mean that the edge is dull according to the Edge-On-Up.
Some of these knives had been used at the time I took the measurements, but not heavily, and none of them had been sharpened. Light use does not show up on the goniometer. Some of the knives belong to me. Some of the knives I measured in a local store.
The <<<\>> stuff is a crude graphic representation. I will not know whether that works until I post. Here goes.
Code:
Make Steel Model Left Right graph
Boker 7Cr17MoV Magnum Air Force Rescue Flipper (35,40+) (21,40+) <<<<<<<<<<<<<<<<<<<<|>>>>>>>>>>>>>>>>>>>>
Spyderco VG-10 Endura Thin Red Line (27,45) (19,35) <<<<<<<<<<<<<<<<<<<<|>>>>>>>>>>>>>>>>>>
Gerber 3Cr15MoV Haul (14,33) (18,40+) <<<<<<<<<<<<<<<<<|>>>>>>>>>>>>>>>>>>>>
SOG Cryo D2 Terminus XR (21,33) (17,40) <<<<<<<<<<<<<<<<<|>>>>>>>>>>>>>>>>>>>>
Buck 420HC Spitfire (9,28) (22,40+) <<<<<<<<<<<<<<|>>>>>>>>>>>>>>>>>>>>
Cold Steel 8Cr13MoV SR1 Lite (19,34) (20,34) <<<<<<<<<<<<<<<<<|>>>>>>>>>>>>>>>>>
Chris Reeve Damascus Large Sebenza 31 35 30 <<<<<<<<<<<<<<<<<<|>>>>>>>>>>>>>>>
Vosteed 14C28N Raccoon (19,33) (19,32) <<<<<<<<<<<<<<<<<|>>>>>>>>>>>>>>>>
SOG Cryo D2 Flash AT (24,40) 24 <<<<<<<<<<<<<<<<<<<<|>>>>>>>>>>>>
Benchmade Damasteel Emissary 470-131 (25,32) (20,30) <<<<<<<<<<<<<<<<|>>>>>>>>>>>>>>>
Case Tru-Sharp Tribal Lock (19,22) (26,40+) <<<<<<<<<<<|>>>>>>>>>>>>>>>>>>>>
Benchmade 154CM Mini Reflex II Auto (18,30) (23,30) <<<<<<<<<<<<<<<|>>>>>>>>>>>>>>>
Chinese 440 Flipper 20 40 <<<<<<<<<<|>>>>>>>>>>>>>>>>>>>>
Piranha CPM-S30V Predator Auto 30 30 <<<<<<<<<<<<<<<|>>>>>>>>>>>>>>>
Frost ? Fire Fighter 33 26 <<<<<<<<<<<<<<<<<|>>>>>>>>>>>>>
Hogue 154CM X5 (20,30) (17,27) <<<<<<<<<<<<<<<|>>>>>>>>>>>>>>
SOG Cryo D2 Aegis AT (22,40) 17 <<<<<<<<<<<<<<<<<<<<|>>>>>>>>>
Spyderco LC200N Pacific Salt 2 (11,38) (14,19) <<<<<<<<<<<<<<<<<<<|>>>>>>>>>>
Kershaw 14C28N Knockout 17 (23,39) <<<<<<<<<|>>>>>>>>>>>>>>>>>>>>
Spartan Blades CPM-S35VN Enyo Elite Gold Grade 28 28 <<<<<<<<<<<<<<|>>>>>>>>>>>>>>
Kizer N690 Vanguard Mike Vagnino Zipslip 20 (23,35) <<<<<<<<<<|>>>>>>>>>>>>>>>>>>
Spyderco VG-10 Stretch 2XL LW (16,38) (13,17) <<<<<<<<<<<<<<<<<<<|>>>>>>>>>
Kershaw D2 Payout (20,27) (14,27) <<<<<<<<<<<<<<|>>>>>>>>>>>>>>
James Brand Magnacut Kline (19,29) (17,24) <<<<<<<<<<<<<<<|>>>>>>>>>>>>
Sarge 440 SK-916 Gut Hook 26 27 <<<<<<<<<<<<<|>>>>>>>>>>>>>>
Spyderco LC200N Subway Bowie 28 25 <<<<<<<<<<<<<<|>>>>>>>>>>>>>
A.G. Russell 8Cr13MoV Sea Skorpion 25 27 <<<<<<<<<<<<<|>>>>>>>>>>>>>>
Benchmade D2 Claymore Auto 21 (17,30) <<<<<<<<<<<|>>>>>>>>>>>>>>>
Civivi 14C28N Cogent 25 25 <<<<<<<<<<<<<|>>>>>>>>>>>>>
Gerber 7Cr17MoV Covert (17 (13,33) <<<<<<<<<|>>>>>>>>>>>>>>>>>
Protech Magnacut Malibu 25 25 <<<<<<<<<<<<<|>>>>>>>>>>>>>
Spyderco CPM-S45VN Para 3 (15,25) (17,25) <<<<<<<<<<<<<|>>>>>>>>>>>>>
LionSteel CPM-3V T6B CVB 23 26 <<<<<<<<<<<<|>>>>>>>>>>>>>
Sencut 9Cr18MoV Sachse 25 24 <<<<<<<<<<<<<|>>>>>>>>>>>>
Civivi 14C28N Cogent 23 25 <<<<<<<<<<<<|>>>>>>>>>>>>>
Kizer CPM-S35VN Hyper 23 24 <<<<<<<<<<<<|>>>>>>>>>>>>
Off-Grid 14C28N Rapid Fire Rescue 17 (21,29) <<<<<<<<<|>>>>>>>>>>>>>>>
Spartan Blades AUS-8A Enyo Field Grade 23 23 <<<<<<<<<<<<|>>>>>>>>>>>>
Miguel Nieto AN-58 Campaña 0100 Aluminium 20 25 <<<<<<<<<<|>>>>>>>>>>>>>
Benchmade M390 Bugout Aluminum 535BK-4 21 23 <<<<<<<<<<<|>>>>>>>>>>>>
Benchmade CPM-20CV Griptilian 22 22 <<<<<<<<<<<|>>>>>>>>>>>
Benchmade CPM-S30V Mini Griptilian 556 @A 21 23 <<<<<<<<<<<|>>>>>>>>>>>>
Civivi Damascus Appalachian Drifter 26 18 <<<<<<<<<<<<<|>>>>>>>>>
Civivi 14C28N Cogent 24 20 <<<<<<<<<<<<|>>>>>>>>>>
Gerber 420HC Strongarm 19 25 <<<<<<<<<<|>>>>>>>>>>>>>
Hogue CPM-20CV Deka 22 22 <<<<<<<<<<<|>>>>>>>>>>>
Vosteed Nitro-V Valkyrie 20 24 <<<<<<<<<<|>>>>>>>>>>>>
Zero Tolerence CPM-20CV Martin Flipper 0609 24 20 <<<<<<<<<<<<|>>>>>>>>>>
Benchmade CPM-S30V Emissary 3.5 Assisted 477-1 26 17 <<<<<<<<<<<<<|>>>>>>>>>
