- Apr 10, 2007
Yesterday, I inherited a safe from my work that had a broken keypad. Being handy and adept at redneck engineering, I tore the keypad apart and fixed the issue with a soldering iron, pieces of a broken pen, 5-min epoxy, 3 beers, and some expanding foam. It works great now but while I was playing locksmith, I noticed that the mechanism is extremely simple and if it ever failed, my expensive stuff would be locked in there until I went at it with a cadre of destructive power tools for several days.
You see, the keypad is attached to the front of the safe and is totally self-contained. Coming from the keypad are two wires entering a hole that the keypad covers and go to a solenoid inside the door. When you enter the correct combo, power goes to the solenoid, dropping a pin in the locking mechanism and the handle can be turned, opening the door. The problem is, if the solenoid ever burns out, the connections corrode, my son pours a glass of grape juice on the keys, etc. then there is no way to open the darn thing.
What I'm wondering is: Do any of you guys know of a small safe that can be accessed quickly (ie, not a dial) but doesn't rely soley on electronics? This appears to be along the lines of what I'm looking for, having a key which I imagine is part of a mechanical mechanism and not just a means to turn an electronic switch :
http://www.sentrysafe.com/Products/240/DSW5781_Electronic_FIRE-SAFE_
What are your thoughts? What do your store your precious in?
