- May 24, 2010
I went to a local store to buy a leatherwave because I had exactly the money I needed in my pocket but I ended up buying this and a couple tins of grizzly so you fellas better be as mad as I was. :grumpy:
I found this in the bargin bin for $10
By laxer11attack at 2011-03-03
Clearly the same shape as the skeletool
The blade has no point, wicked play in every direction and the thumbhole is too small to even be functional.
On the other side they have a tiny crappy hidden little saw
The pliers are spring loaded, the wire cutters wouldnt even cut headphone wires and the handles are sharp
The hole for the screwdriver tips is terrible. you have two heads you can use and they both are terrible
The clip came bend so theres no pocket retention at all
This is an absolutely terrible knockoff of a great knife. if you're going to go to this length to copy a knife at least make it comparable.
