I was gifted a Falkniven TK2 and although I would like to believe that the quality lies in the blade the rest of the knife leaves much to be desired. Handle fit to guard was poor, blade finish rough and the zytel sheath crap.
I have also had one of their folders in my hand and it was a beautiful piece to behold, no reservations.
One other point, I mailed Falkniven to inform them and their reply about the TK2 was surprising: They admitted that the sheath was only "fairly good" being robbed from the F1 but said that they had never seen a rough finish to one of their blades and that I should return the knife for their inspection. Worth 400 Euros?
Mine is solid as a rock and the blade moves silky smooth around the pivot!
Tight lock and no bladeplay.
That said all japanese folders I have handled, has a small play around the pivot.
This is due to a slightly larger hole in the blade, than the pivotpin.
Nothing to worry about and it's nothing I notice when using the knife.
The Cobalt steel is great
It holds an edge extremely well, because of the steel and heat-treatment, but it also has a large edgebevel.
When sharpening, wich isn't often, I tend to thin the edge.
I have also convexed the "shoulders" on my GP.
The final finish is more production than custom, but hey, it is a production knife.
For a modernised traditional pocketknife the GP is a nice way to go.
The pocket sheath is from KSF.
Regards
Mikael
Can you open the fh9 or gentleman's with one hand, with your thumb against the blade?
Thank you. I like the sheath too. I'm convinced now. I'll be adding a GP to my EDC rotation
I can't open the FH9 like that.Can you open the fh9 or gentleman's with one hand, with your thumb against the blade?
I find it difficult to make a comparison between the FH9 and William Henrys. They're completely different knife designs. Among other things, William Henry doesn't make lockback knives. They make button lock knives. But beauty is in the eye of the beholder. And there is no arguing taste.I just got the FH9 in 3G.
Great knife. Personally, I find it more visually appealing than the William Henrys other than the REALLY fancy WH'es.
Hi Mikael, The TK2 retails over 400 Euros in France, FACT. I see that you are from Stockholm and therefore understand your patriotic stand but let us not confuse constructive criticism with national pride. Your after market work looks beautifully executed but I ask the question, " why should this be necessary on a knife of this price?"
the reply from Falkniven was an open admission that the sheath is sub par and they recommended that I try a leather option, fair comment as I see their leather is of high standard. When the TK2 sheath becomes available again on the HH site, I shall place an order.
This however does not excuse a poor handle to guard fit but I see the same on the Virtuovice review, so this is not a one off.
My blade was poorly finished with circular sanding marks on the blade near the tip and it was far from sharp.
I am sure that the steel will make up for the rest of the quality!
