Fallkniven knives with black blades question
Tombo 65
I love Fallkniven knives.
I have less love for coated blades. I know some like the badge of use that abraded coating becomes. I tend to favor the lack of resistance a clean finish gives when cutting thru thicker material.
All my Beckers have been stripped and oiled after use, but I know there are circumstances where a coating helps limit exposer of carbon steels to the elements in circumstances where normal knife care may be impossible or inconvenient.
One caveat to my dislike for coated blades is Spyderco's DLC coating. Back when they first released the Manix 2 XL in the version with the DLC blade, I picked one up cheap, and decided I'd remove the DLC coating. I'd removed a variety of professionally applied coating before, so I thought: No big deal. It was a big deal. It was as difficult and laborious as completely reprofiling a blade can be. In the end I regretted removing the finish that had so valiantly withstood the removal process that would have take me decades of normal use to equal.
To my question. Might be simple one - hoping so.
Fallkniven knives that come with black coated blades - is there a secondary bevel on these blades so you can repetetively sharpen them without having to intentionally wear away coating on a convex blade.
If not, it seems like painting the tread on your tire in order to protect it. That, or you have to fall into the group that likes the wear marks (not putting you down if you fall into that group. I'm just not a member).
The reason I mention this is I've seen a few black coated blades come up for sale or trade over the years and I have never jumped on one because the grind and coating seems about as harmonious as a fully coated scandi-ground blade.
Can people offer more info to enlighten this dull-witted geezer.
Makes sense, sort of. The Fallknivens I've owned have been convex ground and sharpened as such. One of the reasons I love their blades. Not a huge fan of VG10, but nothing wrong with it. I will say of all the Fallknivens I've owned (non coated), non have ever showed significant staining as some high-carbon stainless blades do. A touch brittle, but so am I.
I really appreciate the factual info and photo. Convinces me to steer clear of the coated blades so they can go to someone who can show them the love they deserve. I believe all knives deserve love.
My thankfully deceased felonious uncle used to say: "All woman deserve love, and I've selflessly devoted my life to attempting to meet that need."
I, and most of the women he met, felt his aspirations were neither high-minded nor altuistic. In fact, any attention he offered typically produced results contrary to his stated intentions.
I'll stick with uncoated blades - stainless or carbon, with the exception of a few DLC Spydercos. Any attempts by me at showing love to any other coated blades are likely to produce results contrary to my stated intentions.
After having unintentionally stripped off all forms of blade coatings over the years, today the only coating I have is DLC. I believe Fallkniven's black blades are Ceracoat (not Cerakote). Not sure of the exact difference if any, but either way it is not very durable.
All my Fallknivens are satin. Except for my mirror safe queen.
I hope you won't mind sharing pics of the mirror safe queen, now that you have my full attention🤪
I'm with you on Ceracoat and the various iterations of miracle ceramic-like heat-cured coatings. I have tried a lot of them on firearms, and removed a lot of them from firearms. Definitely not a fan. Closest I'll come to a coating is parkerization. Parkerized a Browning Hi-Power years ago. Different type of tool, though. I have always felt that any finish or coating (other than DLC) breaks down at the transition where the sharpened edge ends. As such, it creates drag when cutting. Not as noticable when you chop or hack things, but try slicing or doing long cuts in wood. Mirror finish on any surface that can contact the material being cut is my preference. Nothing slides thru stuff (of all varieties) like a fine-grained mirror-polished blade.
Put a mirror polish on a Rokka Korpisoturi last year. It cross-cut communion wafers off 1-1/2" dried birch limbs with no more resistance than a SpydieChef thru a carrot. Gave the knife to my brother becaused he liked it. One of the latest instances of my lifelong questionable decisions streak.
I'm with you on not wanting the coated ones. When it wears it just looks awful. I'm told some of them are more wear resistant than others but don't see any particular need to find out.
Ceracoat is the same as Cerakote. It's about as durable as wet toilet paper. I hate it and wish companies would stop using it on knives.
I don't like coated blades, but if it's not DLC, I won't even look at it.
Sorry, my photography skills are so lacking.
