- Oct 29, 2012
Hi Memebers. I was just wondering what peoples opinions were on super-tough medium large to medium survival knifes. I considered choosing from the following group: Fallkniven; NL3, A2, A1 and S1.
Firstly I read the A2 and A1 are 'almost' full tang, but I'm not sure about the NL3 in this department.
Next is blade thickness. From Fallkniven's description of the A2 it would appear that it is built tougher than the A1, but given the specs I dont think it is. The A2 is the same thickness as the A1 at 6mm, yet it is longer at blade 8", where A1 ia blade 6.3", so you would assume the A2 is more vulnerable. The NL3 on the other hand is shorter than both, at blade 5.9" and thicker at 6.5mm so I would assume this is the strongest of these knifes.
Just to through a spanner in the works, I am also considering the S1. I know it is not as strong as the other 3, but I like the fact that it is full tang, is sufficiently strong at 5mm thick and is quite compact blade 5.1", yet capable of light chopping tasks.
Any expert suggestions would be greatly appreciated!
