Fallniven F2 and PHK, Surefire Echo and Cold Steel RT Carbon V
PRICE UPDATE JULY 1rst.
The Echo and the RT are used but in excellent conditions, the Echo I purchased used and it did not have the diamond hone in the tec-lok. The RT is sharp but the echo could use an edge polish, 3V is a little toothy. The F2 is new unused but the sheath shows signs of storage (a few dings in the leather).
Cold Steel Recon Tanto $75 shipped and PayPaled
Surefire Echo $old
Fallkniven F2 $80 shipped and PayPaled
***Added***
Fallkniven PHK in 3G lam with custom black G-10 handle $200
Doesn't close around the loop but fits the sheath. You can have a custom sheath made or if you are handy you can fix the loop.
I'll take the A2
Edit: Withdrawn if it's the F2 like it appears to be in the picture.
Sold PF. I'll PM you the PayPal address. Please notice that it is an F2 not an A2. I'll correct that.
What did you use the Echo for that needed that much sharpening and what did you use to sharpen it to make it look like that? Did you just decide to sharpen a different angle to remove more of the coating or what? And finally, what do you mean by "toothy"?
Its a chisel grind, the angle was too high and sharpened it to relieve the primary bevel a little. It still has a lot of metal on the edge. Toothy is that the edge even when polished by a ceramic rod still a little rough, it does take a fine edge but you need to hone it with several finer stones.
