Carbon steel Mora is thought to be somewhere between 58 and 60 HRC.
I'd need to see a picture of them, but going through 15 of these by hand will take a long time to put the original Scandinavian grind back.
That said, most of my Mora's don't have scandi. The user knives have, as you say large micro bevels, and some as large as 1/8+ inch. When I'm working on carving hardwood that dulls knives quickly, I don't have time to sit there and work out the full scandi. I cut a quick new bevel with DMT XC, strop a few times on DMT fine, then it goes right back to working.
The only Mora's that I have that retain their full scandi are ones that I reserve for softwood carving. Scandi offers advantage there with smoother cutting actions.
In outdoor situations, I would definitely not recommend scandi grind. Soft materials like ropes, meat & skin, bandanges, etc. simply don't care what kind of geometry you put on that. Harder things like shaving/splitting small pieces of wood for tinder, etc. prefer convex geometry which tends to "split" the material you are trying to cut and reduce the compression onto the blade. What you have, large microbevel, with thinner blade behind, is essentially convex and should work very well outdoors.
In summary, look for ones where the geometry is simply too thick to cut well. Thin those down. Grind that microbevel down so it has a keen edge and pass those out.
