I love the Buck 110 - but, it may just be that size of large pocket knife!
What other 'look alikes' to the 110 lockback do folks have?
I have a Western near-copy - and a Bear MGC, made here in AL, # 297.
Little things pop up - the Western has a darker 'solid' looking scale - possibly of Indian rosewood (Not as figured as American variants.). It and the Bucks are straight and, other than the pivot pin, would lay flat, while the Bear's are much thicker in the center, causing them to rock. The nicely finished oak scales on the Bear have only a ground flush lock pivot pin, while the Bucks and the Western have similar brass scale rivets and steel lock pivot pin. It's pivot lockback arm is a little longer, requiring less effort. It and the Bear have a somewhat lopsided closed blade, the Buck being more centered. Releasing the Western's locked blade is easiest, followed by the Bear, then the Bucks (I have two 110s, a 110Ti, and a 110 'Alaskan Guide'.). They all lock positively, with no play.
The blades are similar in size and shape, but the Western and Bucks, after several years of ownership and some use opening packages, etc, can still shave arm hair. The new Bear came considerably less sharp. The Buck holsters were marginally finer.
I won't compare the Pakistani SS copy from years ago... it was $4 at a flea market - probably 20-25yr back... very crude.
What other examples have you guys found?
Stainz
Stainz
