NOT better for chopping unless it's of equal grind angle to a full flat, in which case it's actually weaker than the FFG because of its thinner stock.
A saber grind has less surface area, yes, but also must displace more material during the cut, which prevents it from biting as deep during a chop. It loses energy because it has to push a larger volume of wood to the either side of the blade than a FFG ground from stock of equal thickness.
This increased matter displacement also happens to be why saber grinds are better for batoning, as they push material further to the sides per inch of vertical travel than a full flat.
Yep, this is it. I'm not quite sure where my previous post said that sabers were better at chopping, but the bolded parts up above exactly describe it. The Saber acts as a much better wedge for splitting wood. But the part that makes it better for splitting, also does hurt it when it comes to chopping if the blades are the same height. But I'm willing to sacrifice a little bit of chopping performance for a stronger knife for batoning, as a folding saw does most of my cutting while camping.
Saber grinds also put a bit more mass behind the blade compared to a FFG of the same size, so that extra mass might help some when there is not much penetration, but I'm not really sure how that would counteract the more obtuse edge angle, as I'm no scientist, and am not the most experienced person around.
Also worth noting, is with thicker blades (aka, my BK2), the edge doesn't even actually hit the wood once you're really batonning with them(typically). The edge angle on the BK2 with the saber grind is actually splitting the wood sheerly by the wedging action (keeps the edge nice and sharp
And finally, I personally feel that grinds make proportionally more of a difference on thicker blades. For instance, a 1/4in thick knife with a scandi grind would be ridiculously obtuse (why we don't see any most likely), but a FFG would be much thinner at the edge. But on an 1/8in thick blade I don't feel like the difference would be as drastic, but I really have no "proof" to back this part up, it just makes sense to me.
And I noticed someone said right hand chisel ground for machetes... is that common? I've never heard that.
