FBM Specs
The handle is going to be the same as the FSH,
The blade? 9" or 10"
Can I spec the LE with handles other than Snake (paper magnums for example), can it have the penetrator tip?
The prototype is 10" so the production version will likely be the same. Regarding handles, there might be some choices but if not you can always check with the shop if they have any other handles. Since the handles will be the same as the FSH they might have some others that they can put on for you. You can always call the shop and check.
I heard from someone that oughta know - the LE's will come in the configuration shown in Jerry's pic. That will be the standard: Satin finish, numberd, Tiger Hide magnum grips. Any other configuration will likely be considered a special order and will result in a longer wait time, if they even will allow a variation. Maybe as a custom order, but you'd have to check with the shop...
I personally love the grips that are on that LE and thats how i will be getting mine though I've seen some other combo's that would look sweet on there.
The CG has a very nice swedge on it as it is, might not need the PT, but that is just my opinion. :D
