- Aug 2, 2014
Just saw this video (at 4:00):
http://youtu.be/M15Bg5js3y8
It is an excellent example of what can go wrong if you hit a small tree. Not that big of a tree being taken down but if he was directly behind it he may have been hit in the chest or face. You can be severely injured from a tree as small as this one. The biggest danger here would be for the tree to snap and fall back towards you or cause branch breakage which could fly back at you. I think I would have cut the smaller one down as well if it was in the natural lay.
Mostly I cut 8"-15" trees, not that big either but still a danger. Generally I check for branches/widowmakers/rot, then head and side lean, pick the safest lay possible, clear all branches for getaway paths in a few directions, clear the bark for notches, and check for sway again after the first few hits.
Anything you all do? What do you think is the greatest danger? I would say any sort of collision with other trees increases danger the most, or cutting in the wind, slopes, improper notches. But I'm sure I missed a few things.
Didn't really see any threads on this.
