- Jan 26, 2002
Shgeo,
sorry, if you looked earlier and found nothing--I got delayed.
For (Fe)3 (C), as far as I can tell, the periodic solid structures are going to be a cubic lattice of Fe atoms, with either face-centered or body centered carbon atoms. And that's been around for a long time.
In fact, somebody, probably Mete, posted links with some pictures a while back.
If you're interested I can post a qualitative description of how that makes sense, chemistry wise. I get a charge of -1 on the carbon and + 1/3 on the iron atoms.
Coming up with a cyrstallographic unit cell for the body-centered case will be easiest.
First, just to try to get on the same page, a unit cell is derived from a space lattice or internal co-ordinate system that depends on which of the seven crystal systems the material exists in. This space lattice is totally different from the crystal lattice that the atoms ocupy. In very simple structures of pure elements the space lattice points occupy the same position as the nuclei. This is very, very unusual.
The general definition of a unit cell is a volume defined by three angles and three pairs of lines whose ratios need not be 1:1:1. Fortunately, life is a little easier in the cubic crystal system that we are discussing. The three angles are 90 degrees. The lengths of the lines need not be equal.
I think I have the unit cell for the body-centered cell, but I have to make a model to check and figure out how to describe.
The face-centered instance is more complicated. I may think about it, maybe not
PS: "Tinkertoys" make stuff like this easier, and are not real expensive.
I have a couple old sets of these, but it looks like nobody sells the sets anymore except Aldrich chemical supply--dunno if they sell to individuals
add a little flexible tuping or a few pipe cleaners and they will handle most stuff.
http://www.edumodel.com/2parts.html
http://www.sigmaaldrich.com/cgi-bin/hsrun Distributed/HahtShop/HahtShop.htx;start frmCatalogSearchPost?ProdNo=Z203467&Brand=ALDRICH
I've used these, many more atom types available , but I like the former better if lots unusual co ordinations aren't needed . One of the crystal lattice sets should do nicely.
http://www.indigo.com/models/orbit-molecular-model sets.html
Or you can use min-marshmallows/playdoh and toothpicks!
