No. Most blades are tempered at around 400ºF or higher... To ruin the heat-treatment you would have to get the entire blade up to above 400ºF.
What about knives with low HRC heat treating? Like Victorinox and Case's Tru-Sharp...
I've always wondered this too.
I thought heat treating was generally north of 1500 degrees depending on the steel?
heat treating is done at that temp, but at the end of the process the steel is very hard and brittle. To let the steel be more malleable and "tough" and keep it from shattering, it is tempered at 400 or so degrees.
That blade is subjected to "sparks" more than any real heat, and to a VERY small area of the blade. Any heat there is quickly drawn away by the rest of the blade...thermal conductivity...
No, it won't. Also, don't use the edge of the knife. Square a spot on the spine off, if you already don't have a squared spine.
