Ferro Rod Trouble
My first Ferro rod was a RAT Cutlery Fire Tool, with a 3/8" rod. In the process of learning how to use it, I "skipped" the back of my blade off of it quite a bit, resulting in a notchy uneven surface, that is now difficult to get a consistent stream of sparks from.
I want to return the rod to a somewhat smooth surface, can I do it with sandpaper, or a file, or what would you use to grind the surface down just a bit to smooth it out? I imagine using a metal file would be exciting :eek:
I use a file to remove notch lines that get formed often at the bottom part of my steel. If you don`t generate too much speed while filing it makes powder rather than sparks.
I've never filed one but when cutting them down to size I either go slow and clear the dust away as I go or saw them under running water. Not that its that dangerous ( unless you cut or file enough to create a BIG pile of shavings) but...
What causes that to happen? I have a lmf that has that, but a couple others that don't.
It happens when you stop your striker before sliding off the end of the rod. I do this often because when I strike, I insert the tip of my rod into my tinderbundle and hold it there while striking. In effect, as I peel of the metal on the rod, I`m forming a notch in my rod. The method generates a lot of hot sparks but wears down your rod faster.
Just carry on using it, the end eventually snaps off giving you a mini rod to keep in your wallet !:thumbup:
A piece of hacksaw blade used as a scraper will sort those notches out in no time, and then you can go back to using your knife.
thanks for a good post: I a bothered by the grooves in my firesteel, too; but I was afraid that any method of smoothing them would be a little too sparky to be safe. But these ideas sound fairly safe if used with caution.
