Respectfully, I must disagree. Carbon steel is what makes the sparks when you're using flint (not ferrocerrium) and steel. When using ferro rods, it is the ferro rod that creates the sparks - that's why you can use glass or rock, etc. to strike the ferro rod.
Doc
Correct. The Ferrocerrium (mush metal) is getting shaved off when using a rod. Conversely, the flint is shaving off little slivers of carbon steel when using a flint and steel. Its the shavings that make the spark. You can use anything harder than your ferro rod and sharp enough to shave it to get sparks from it.
A lot of hacksaw blades, from what I've read, are somewhat harder on the teeth side than the back side. If you ground off the teeth, you should still get more sparks from the teeth side. Never had enough free time to test the theory, but I'm quite willing to listen to anyone who's tried this.
