- Jul 8, 2002
Well, I bought some fertilizer grade potassium nitrate to test out if it would work as Nitre Blue. I bought a 50 lb bag and tested a small bit on the stove top with an old pan. The stuff looks ugly when melted. It started out as white granuals, then turned kinda brownish when melted. Anyway, the trial test on the stove went well, at least i didn't blow up the house.
So I threw caution to the wind and dumped the whole bag into a stainless steel pot and stuck the 170,000 BTU propane burner under it.
45 minutes later, it was all melted. I did not buy a high temp thermometer so I don't know what temp it was at. I tried to keep it just melted, probably around 650 deg F. As with the lead (if you all read that post) the salt would solidify and adhere to the steel. But after the steel had a chance to come up to temp, everything was OK.
It took a little trial and error, but what I came up with was a 5 second dunk with a 30 wait between dunks (after the salt stopped sticking) until I got the color i wanted. Once the color was acheived, I quenched it in water.
Anyway, below is my test piece. I buffed off the color from half the piece so you could see the color change better. I think it is kinda neet, but I don't know if there is any advantage doing it this way or just using a torch or HT oven.
Any of your advice on this subject would be greatly appreciated.
