FFFBM Grip Material?
I have the black/black/magnums from BCS.
I thought they were canvas micarta, but several listed on the ex said G10 with pics that looked exactly like my knife.
I really don't remember.:o Were the plain, basic, BCS, FFFBM's all G10? Micarta? What?
Thanks!
Rob
I believe there were both...
I know the black w/ black canvas came in both standard and mag.
Here's my FFBM with canvas mag...
I would think canvas micarta would be pretty easy to tell apart from G10. I can make out a pretty clear "weave" pattern in the canvas on the hand-shaped micarta handles on my NMSFNO.
Thanks Foo, that's it, more gray than black. What a beaste! Makes my SHBM feel like a fly weight.:D
Considering putting it on the block and wanted to be accurate with any descriptions.
THANKS MM! ;);) Now, I've got Sgt. Peppers running in my brane.:D
Rob
G-10 has that same weave pattern, I can clearly see it on mine. But the weave is white on the black resin in G-10 while the canvas appears to be closer to the color of the resin.
G-10 uses a fiberglass matting, while canvas micarta is self explanatory. Fiberglass will not dye black with the resin like canvas does in micarta.
I definitely don't find the weave to be as noticeable in g10, but then I don't have enough of either to make a detailed comparison. It probably depends on things like color and individual batch.
snip...
... snip
Rob
True dat!! :D
If more porkers could get their hooves on a SHBM,
I'm sure they would be king of the hill. ;)
Or would that be queen of the hill??? :confused:
being a mistress and all. :p
black canvas micarta looks greenish gray fresh milled till you spit on it, then it turns black. :thumbup:
On my FBM the black G-10 has noticeable white weave showing, my badger is the most outstanding of the bunch, it has a speckled appearance even several feet away. The others I have dont show as much unless you get close, but even then I can see the weave.
Spit test says it's canvas micarta. ;);)
Was pretty sure that's what I ordered but, started reading and confused myself.:o
Thanks Guys!
Dwayne, long time, how's it going? Good I hope.
Rob
Rob
eh, could be worse, the house could be falling apart around my feet and the truck could be rolling down the street by itself.
