Field Report
Last week I made a trip back to visit my parents and my childhood home.
Kentucky, about 20 miles South of Louisville.
Since much of the land is wooded, I packed a couple of khuks to exercise.
There was a 14" snot-nose pug villager, and an 18" AngKhola beauty.
What a difference 4" make. The AK is about twice the weight and in hand
feels almost twice as long.
The AK kept me company in the woods. I was going in to cut a few straight
saplings for walking sticks. In addition to a chopper, I wanted something I could
use to shield myself from a snake if I failed to see one soon enough.
Dad told me an 6' rattler had appeared over the hill on someone's back patio.
Not many ancients like that running, errr, slithering around. But the babies are
problem enough when you're running around in hard-sole mocs.
Anyway, back to the khuks.
Average sapling size 1", so not much of a test for an 18" AK.
But, I also used it as a shovel and pry bar while digging up some of
the saplings with root intact. In several cases I chopped directly into the
stony (mostly softish stone) loamy dirt to cut a thick root.
End result on the blade was:
Last 2" of tip blunted flat, dented very slightly.
Belly had about an inch of edge flattened, blunted Very slightly.
Otherwise it stayed plenty sharp. Chakma worked out much,
but not all of this when I sat down later to peel and smooth
the trunks.
I used both khuks and their kardas to work on the sticks.
Comments RE the AK apply to the villager as well, just not to the same degree.
The 18"AK was handier than I expected when peeling thin bark.
But, I had to find just the right angle with the AK, in order to get under
the bark, but not cut into the wood. The kardas, on the other hand,
were thin enough that angle was not very significant.
Sliding the khuk down the stick is an easy way to shave off/down the nubs of
twiggy branches. The 2" area of the khuk edge just in front of the cho makes
a good draw or push knife. Again, the angle is important. And sitting on the
ground I was too close to the work to draw the blade toward me safely.
One reason for this region working is that the blade balances near here
and it's comfortable to hold with the weight resting on the work.
This area is also great for smooth scraping. Hold the edge perpendicular
or slightly lagging the direction you scrape.
I learned a trick for fine shaving with a big blade.
(Right handed descriptions follow. Harder to describe than to show.)
With a stick pointing away from your body,
rest the blade on top, pointing left,
blades balance point about 2" to the left beyond the work,
blade edge toward you and toward the area to be shaved.
Heel of the hand resting on the handle side furthest from you,
thumb on top the blade, index and middle finger around the blade spine,
this postion should make you feel that the blade is pretty well balanced and
controlled in your hand, and the actual weight of the blade is on the work.
Lift the spine of the blade off the work to get the cutting angle you need.
The idea is to rock the handle of the blade toward you by pushing with
the heel of your hand. Inertia does the rest.
The blade will pivot around the balance point which is out in the air to the left.
Both ends of the khuk move an inch or three,
And the cutting edge an inch or so in front of the cho will move just
enough to shave a tiny bit. Move left and right to get the cut you need.
Adjust everything to suit your own blade, grip, and other factors.
You did OK explaining that to me. Just clear as mud. Just jokin! Do you think the long blades are better for the draw knife work? I was thinking about a 15" Siru. Mine is just pretty darn sharp.
Maybe the weight of the bigger knives would help on those bumps where the nots are. Didn't Mr Holt say he used his 25" Kobra for that job. I guess it would depend on what size material a feller was working on. Besides you were out with only two khuks so, it wasn't like you had much choice.. One or the other or nothing.:)
Excellent field report! I've used my pUgly villager and small AK for stripping bark as well. I was able to de-bark a hickory sapling in no time at all.
Ain't Khuks Wonnerful!:D
-Craig
What gets me about a khuk, is that even the smallest ones can do so much more than I could ever get done with a plain straight blade knife. My little neck knife will work most knives of it's size in to the ground.
Originally posted by Pappy ......Do you think the long blades are better for the draw knife work?
If I had all my knives by my side I think I'd choose the smallest that
fit my grip properly for the work I was doing.
And in case of bigger items, that was big enough
for the cut I planned.
What suprised me was how adaptable the 18"AK was to making
fine ant-size shavings.
IMHO, khuks make better drawknives than drawknives do... I find that for planing knots off round poles,the sweetest spot is the bend of the blade. For flat surfaces, the straight blade and edge geometry of the kobra works very well. Khuks with thin edges, such as my long sirupati, tend to bite into the wood without planing it.
I took my 18" AK for a walk the other day.Took a 3" sappling in one swipe :D.Then for the hell of it I took an empty beer can and almost cut it in half from top to bottem.I have to take a picture of it to show u guys.Sweet knife !!!!!;) And definetly makes a very good draw knife.Made a nice walking stick for the wife with it.FRANK
