I'm inclined to believe that if one knows or at least speculates they're going to be 'in the field' for months at a time, then one should rationally weigh the trade-offs between (a) carrying one or two small, lightweight hones, which will work FAR BETTER in maintaining any knife's edge, convex or not, or (b) not carrying anything to maintain the knife's edge and instead relying on pure luck in finding some rock or other implement which may or may not do an adequate job. Carrying the right tools for the task, especially when many of those right tools might only weigh a couple ounces, will buy a lot more peace of mind, when otherwise nothing else simply 'found' in the field would get the job done.
The vast majority of natural stones will only be marginally harder than most knives' basic steel composition - and never mind supersteels with very hard carbide content, for which virtually nothing you'll find on the ground will be adequate to resharpening those. And the grain structure of many natural stones, depending on geologic regions where they might be found, won't often be suitable for sharpening anyway, being either too coarse or too irregular in grain size, or too blocky or too rounded in shape and therefore structurally incapable of cutting hardened steel. Just picking up a rock off the ground and sharpening away sounds exciting - but it's not usually going to work so well (if at all), depending on what steel is being sharpened and how damaged or dull the edge might be, before the sharpening attempt is made.
At the very least, if one is determined
not to bring the right tools along, then selecting a much simpler and less hard steel for one's blade choice might improve the odds a bit of being able to resharpen it with some simple natural stone. Leave the high-wear steels at home, if you're not willing to also bring a good hone (and a spare) along.
The diamond hone pictured below weighs maybe an ounce and a half and will be capable of resharpening literally any blade you choose to take along. Sometimes the extra ounce or two of carried weight is well worth the trouble if viewed against the possibility of not being able to get the job done with anything just 'found' at hand, when you really need a solution.
