- Jan 12, 2016
I am new to sharpening and I need a good/easy field sharpening stone I've been looking at the work sharp guided field sharpener. Anybody have any others or any comments on the work sharp?
Not exactly suitable for a field sharpener thou1. Find out your knifes factory angle.
2. Saw a piece of wood under half that angle
3. Buy some cheap 2 side stone soak it in oil and place it on the wood
4. Try to slice a piece of the course side of the stone, keeping your blade 100% vertical
5. Repeat step 4 on both sides of the blade, untill you feel the knife becomes sharp
6. Repeat step 5 on the fine side of the stone
7. Glue a piece of leather to a piece of wood and charge it with polishing paste
8. Strop the hell out of that edge
9. Don't cut yourself
10. Clean of the hairs you shaved from your leg, and clean of the pieces of paper you sliced.
This poor-man sharpening kit works like crazy and costs :
Cheap stone : 3,95
Piece of leather : 5?
Wood 0
For example, spyderco uses a 30 degrees angle, so I sawed the piece of wood under 15 degrees. Works great!
I'd carry some simple wet dry in various grits with a mouse pad rather then a big set up...It weighs practically nothing and will get a knife wicked sharp.When there is a will, there is a way.
And otherwise you can always buy a lansky blade medic, can't go wrong for 5 bucks, just don't expect razor edges.
Typically all I have to do when it is touch em up on a strop at the end of the day. I don't think I've ever actually sharpened a knife in the field.
