Fighting Blade
Dudes & Dudettes,
Who here has used REKATs Hobbit Warrior and what do you think of it for FMA applications?
I've been training pretty seriously with mine for a little while now and have yet to find a problem, other than its almost as large as me. :eek:
Should have the WH trainer late this week, and a matching Mike Sastre sheath as well. (C'mon Mr./Mrs./Ms. Postal Carrier MOVE IT!) and really get a chance to experiment "live lab" then.
I'd post a decent pix, but don't know how to do that high follutin PC stuff even with instructions above :o
Ofta work and no play
Pete,
I took the picture you sent me, converted it to a JPG from BMP File, created a ClubPhoto Account for you and I will E-mail you the information and password. Now, you too can enjoy this place more and I'll show you how to convert your own pics (ClubPhoto can only accept JPG Files, not BMP and others) and I trimmed and reduced the size of the photo so it would fit and look better.
Enjoy.
Don
P.S. And don't be intimidated by computers and all of this converting, trimming, reducing, uploading and whatnot, if I can do this, trust me, ANYONE CAN...
I have owned several REKAT H-Warriors and Trainers, as well as the Al Mar Warrior which was much heavier and larger, but the same, basic knife. Different form. Now, that was a HOSS...it was huge and heavy, did not move as fast...
The knife was designed for Reverse Grip, and it is excellent in that mode. It is perhaps the best production (or Customs, they are out there as well) knife ever made for Reverse Grip...
The serrations on the back side of the blade were designed to hook limbs and tear things up internally as well. There is no doubt in my mind that if that is The Game Plan, the knife will work.
The knife has a very comfortable grip and a full guard that you can really thrust as hard as you can without fear of losing your grip or damaging your hand on the blade (by slipping).
I don't know if the REKAT Pygmy Warrior is out yet, but it is basically a Fixed Blade version of the Folder, and it is a little bit more "Street Defense Oriented."
Pete,
I'm no authority on Blades for FMA applications, but I will offer the tidbit..
Kelly S. Worden in his tape series "Connecting the Systems",
Speaks very highly of the Hobbit Warrior. He highlights it's use in reverse grip, showing traps, punyo strikes, and witik(sp?).
He states that in his conversations with the designer, FMA was not a intended design focus, but Worden believes it to be exceptional knife for those styles.
HTH - Seth
That's not exactly accurate. Kelly was using it in reverse grip and then went to forward grip on a fighting dummy and said that the knife was not designed for forward grip, but he found it functional either way. That was a big-assed Al Mar Warrior too.
Opps...
Sorry, The devil is in the details....
I just 'watch' the tapes, true learning is yet to come. If anything, Don Rearic is precise in his communications.
-Seth
Seth,
No, I just wanted to make sure that anyone else reading this would know that reverse grip is indeed in FMAs [sometimes there is a larger audience than "regular" visitors] and although the specific methodology between Hwa Rang Do and FMAs might differ, they come together in places...Universal Movement. Crescent slashing/cutting/hooking/thrusting is basically Universal, the way you get there is sometimes different. And just wanted to clarify that the knife was not really designed for forward grip but worked in that method as well. That's basically what Kelly was referring to in his conversation.
The knife was born from Hwa Rang Do, or I should say, Michael Echanis' interpretation of HRD Knife...it all depends on who you speak with. Most agree that alot of what was in, "The Black Book" was Mike's own Material too...or...others...
(Confusing, isn't it?)
You're learning is yet to come? Haha, trust me, once it starts, it never, ever ceases...when it ceases, you just know what you know. Not necessarily a bad thing...12 years ago, I might have been stuck in a Tantojutsu Bog...
But, you're already learning. And that is a good thing...
Don,
Many Thanks for setting me straight on the photo stuff. I hope everyone likes the layout.
You're spot on with the HwaRang Do, its deadly stuff. Some old associates trained under Mr Echanis and it is SCARY to spar them.
From my limited time and study of MA's it is suprising how many classic schools pyramid up into very similar techniques.
A LOT of my advanced Oki Go-Ju Ryu and some other "dabbles" teach similar close range open hand techniques, slaps and strikes for defense and offense.
The techniques that I learned (some re-learned?) from David Wick at the CMMA seminar brought back some rather painful memories learned in the dojo doing full speed bunkai/kiso-kumite.
Thanks again!!
I've used the Hobbit trainer in FMA classes for a couple years now. I really love it for reverse grip, edge out. For me, it doesn't feel quite right for the reverse grip, edge in (Pekiti Tirsia) material. In addition, my index finger doesn't fit the first finger groove when I hold the trainer in forward grip.
DPD.
Pete,
David Wink's empty hand system is indeed interesting and a bit different than the other FMA empty hands I'd seen before (most of which was from the FMA/JKD groups).
I would NOT want to be on the receiving end of one of Dave's hacks, or slaps, or elbows, etc. Not because he knows any secret techniques, but because he has worked really hard to develop good body mechanics and can generate a lot of power in a short distance. :eek:
Btw, feel free to stop by some Saturday. You don't have to wait for a seminar. That goes for anyone out there that finds themselves in the area.
Respectfully,
Dave Fulton
DPD.
I don't quite understand this. The whole purpose of using edge-in icepick [reverse] is so you cut on first contact with any incoming limb. A methodology that I happen to agree with 100%.
Often times, you will see someone demonstrate reverse grip crescent cutting, say someone comes in with a straight thrust anywhere into your torso, chest or abdomen; you will see the Defender in reverse grip [edge out advocates] come up to get a slash on the inside of the incoming arm [vertical crescent], then hook down to get the hooking and control, boost the arm at the elbow or slightly above it to get the control and either cut [horizontal crescent] to the torso and/or thrust into the torso from that point.
Now to me, this looks very cool and very "Expert," but if you look at this, it has an incredible, if not fatal flaw, a fatal assumption.
The retraction of the thrust is going to be fast anyway, but if you add the fact that you might have just cut the person, they are really going to pull back quickly. Therefore, the chances in that arm being there in that same general area for you to hook down on is just about as close to zero as you can get.
In other words, it looks great being demonstrated and not so great in real life at anything resembling speed.
It took a long time for me to accept the reality of the icepick grip edge-in. The more I worked it, the more I realized the simple brilliance of it.
I understand the reluctance of some who want their edge facing out so they can slash with a single-edged knife. I just don't agree with it if you are basically using any method that uses hooking.
This is the real reason that a double edged knife is more of a fighting knife, especially in reverse grip. Because then, you can cut either way, no matter what you do, everything becomes instantly viable.
But if you have a single edge knife, you have to play a certain way if you want to get real-life results.
Also, when you hook down on a limb, this is more of a tearing movement with the edge than a slashing movement. Plus, there is always the chance that you will drive the point through the flesh and it will tear out...disabling the attacker.
The reason I went over this again and typed all of this out, is to explain what my position is on this quote from DPD and why I don't understand it...
The Hobbit has serrations on the back of the blade to do this, therefore, there is no need to use the knife edge in as there is something on the back of blade with which to damage someone. Those serrations are not like Spyderco serrations, but they are still going to damage someone and control them as well, to a degree.
Also, there have been versions of this knife with the small backside of the tip area, that have been sharpened. As well as fully double edged [no serrations] versions.
Personally, I think it is one of the finest fighting knives made.
So, in closing, I don't see why you would have to hold that knife Primary Edge-in to use it effectively.
Gentleman,
Thanks for the follow ups! Again I learn from you:D
One of my primary reasons for choosing the HW was the dual edge cutting/tearing ability.
Situationally, if needed, I wanna cut (meant universally- generically - to include all types of strikes) fast and quick.
My early training was with a Gerber Command MK ? the 5" serrated tip, and Guardian both with taped handles. Fast in - Fast out was THE RULE.
A Downward Hook/Parry/Trap and Cut combo at hyper speed seems to work well for me and my limited eye-hand ability. The HW gives this naturally due to the grip ergonomics and dual edge albeit false tip. I feel thats a legal eagle issue which can be revolved with a diamond stone, or a pretty please to REKAT.
A REKAT "Pygmy" would be MOST welcomed into my home, as well as the existing Pocket Model. Soon they may here getting a workout on "Mrs Kee-Kah" the tire dummy.
Naturally I'm developing an SERIOUS interest in Kerambits too.
Dave Fulton,
Tell ALL the guys at CMMA I said "Hi" and that I will be back soon (emergency weekend coverage). I DEFINATELY need work on polishing my Curley Howard type footwork Nyuck!-Nyuck!
You can take Mr. Winks strikes for me, I'll pass on receiving any more, thank you very much.....;)
Its time for me to begin AM training, Have a Safe Holiday!
Don,
Thanks for the detailed remarks. I think that I was too casual in my comments and that you read more into them than I intended. To clarify, I have trained with the edge-in reverse grip (using a variety of different training knives) and definitely see the advantages. I did not intend to run that technique down. Second, I understand that the actual Hobbit knife has the serrated back, which makes it unnecessary (and inadvisable) to hold the knife with the primary edge inward. All that I meant to say was that the trainer does not fit my hand well when held in a edge-in reverse grip, if for some reason one wanted to hold it that way. I was merely commenting on the configuration of the handle, not suggesting that anybody would necessarily want to use a real Hobbit that way.
I appreciate your explanation because I would not want anyone to interpret my cursory remarks as a recommendation that the Hobbit be held in a primary edge-in reverse grip. I probably should have refrained from commenting on the comfort level of a grip style that few people are likely to try. It's a good thing that you keep us on our toes and compel us to be precise in our comments. Keep up the good supervision.
DPD.
DPD,
What you call "Supervision" to promote precision, most people refer to me being an "asshole." :D
