I wonder if anyone here on the forums, ever used successfully a figure 4 deadfall. Does it really work? I would assume, that most animals are fast enough to escape. Am I wrong?
I have taken 2 animals with a fig 4 and stopped using them a long time ago.I wonder if anyone here on the forums, ever used successfully a figure 4 deadfall. Does it really work?
Also, I don't think that its a very humane way to dispatch an animal - hence I would personally never resort to them unless I was in a "survival" situation. But I'll probably get flamed for saying that. And also - I'm a hypocrite. Because I really want to bow hunt(traditionally, no less) and you could argue that and arrow would be a shitty way to die too =P
that's the point, I would not test it on real animals unless I really needed to.
On the other hand, if you do not test it, how would you know it works?
This is why I was asking if anyone had experience with it.
I have used them numerous times.. and adapt a 5-1 one rule..a wieght 5x the wwight of the target animal needs to be used.. also you need to set 5 traps if you want any chance of catching one animal.. I have used them primarily on squirrels.. sometimes the traps are triggerd and there is nothing there.. Sometimes the work but, but mostly they are undisturbed.. there are numerous tricks you can use to ensure the effectiveness of your deadfalls.. but I have used them they do work..10 million aborrigninals can;t be wrong..
although I love primitive trapping I'll go out on a limb and say with knowledge of how to maximize it;s potential the fig. 4 is the only survival trap you really need to know.
How can there be any doubt?????
Doc
I like the title of the book that was used as the weight, but the best is the expression on the stuffed varmit....![]()
G'day ml
They will work, as long as you position the animal correctly & restrict its movements (as has already been mentioned).
I stopped using them when both animals showed signs of rupturing of internal organs![]()
Kind regards
Mick
