I've been in the game of finishing knife kits for about three years now and I'm looking to produce my own blades. I thought I would give file grinding a try, but I have a few questions. I've been monitoring the forum here and have found some useful tips. I do have some powertools which include a Delta and Craftsman belt sander, bench drill press, bench band saw and a small buffer. I do plan to give flat grinding a try with the power tools I have, but I would also like to give file grinding a try for the pure satisfaction of a truly hand(bench)made knife.
first, what type of steel should I start with? O1 or other? I have a piece of steel that I actually got from my lawn edger after replacing it with a new one. Any ideas what type of steel it might be?
I understand the basics of file grinding would be to cut the blade to shape (I would do a full tang variety; I have actually drawn a wharncliffe blade that I would like to try to make) with a hack saw or use one of my belt sander/grinders or file, of course. Next, the blade needs to be held in such a way as to allow for unobstructed filing such as securing to a narrow piece of wood which is then held in a vice. How does one apply the plunge grind and with which type of file to get started?
I have also read that draw filing (pulling toward the body) is best as opposed to push filing. Makes sense. Once the steel has been worked down with successively finer cutting files then work begins with hand sanding using successively finer grits beginning with say 220 (wrapped around a flat piece of wood say a clothes pin, popsicle stick, etc.) and working to at least 600 grit making sure all scratches are removed from previous grit before moving on to the next finer grit.
Finally, heat treat the blade (I will probably have someone do this for me) and hand finish to the desired texture/look/feel.
Anyway, I'm sure I've not listed all the fine details which would fill volumes on the forum. I'll elect to save the bandwidth and look forward to replies/answers to my questions.
Thanks all!! >> DeWayne <<
