Hi There,
My first knife attempt has quickly lead to a first post on the forum. I found an old Nicholson file left in a shed in the backyard of a house my family just moved to. I had some time Sunday and decided to test my skills at turning it into a knife. Ive done quite a bit of welding/fabricating, but never attempted a knife.
I took the file and drew out a rough shape to what I thought I was after. After a couple hours with an angle grinder and a handheld belt sander, I thought I had a pretty cool shape. I called it a day and started googling "knife from a file" and quickly realized I had probably gone a little backwards with my approach.
So, am I too far along to salvage this knife? I don't have a forge, but have a propane cutting torch and a rosebud tip that I have used to heat much thicker steel to "malleable" in the past. If the knife is still salvageable, what are my steps going forward? It does not have a cutting edge on it, but it is tapered pretty thin towards the edge.
If any heat treatments/annealing is off the table at this point, should I just try and hone the edge as is and use it until it breaks?
After reading about it more Sunday night, from the looks of my knife, the tip got too hot, should I re shape a little to remove the darkened area?
Any likelihood of me drilling a few holes in the handle and putting a complete handle on without any heat/steel altering approach? I have cobalt bits and a drill press but no carbide.
Lots of novice questions here, I know there are a number of similar threads, but I couldn't find one where someone goofed like me and jumped to step 4 at the start. Any help is appreciated, not attached to it at this point but would like to save it if possible. Cant figure out how to post a picture for referencing...
Thanks
Clayton
Thanks
Clayton
