yes I want to put some of my patterns on disk in that format to save and for easy of transfer for that type work also..I have a few deals in the works to get a head start on..CigarMan said:Dan,
What kind of program is it? Sound like some kind of CNC software.
Bill
dang thanks for the reminder BillCigarMan said:Dan,
You may want to check this out. It's a free CAD program I use. It's very easy to use and if you ever want parts cut out for you, it's a breeze. I design and save all my patterns this way. When I want to make a knife, I just print out the patterns and glue them on the stock.
http://www.emachineshop.com
Bill
Dan Gray said:dang thanks for the reminder Bill
I put that on my wifes puter a long time ago. I'll have to up date it, if I remember right, they need to download junk from time to time? pricing info mainly I think..I didn't at the time mess with it much..I'll have to now.:thumbup:
hijacking a bit how do oyu go about using emach. to figger out pivot placing on a folder and how can you set the main grind line i have played around with the program but played is the best way to describe itCigarMan said:Dan,
Bill
thanks BillCigarMan said:Dan,
There are a couple of things you can do. One is that you can right click on the drawing and shut off the snap options. Secondly, you can go into the edit>preferences menu and change the spacing between the grid marks.
Hope this helps
Bill
Bill Have you tried to e-mail a DXF file from this program?CigarMan said:Save them all as EMS unless you are transferring to another program.
