It's really difficult to tell you an angle
because of the many different patterns and
styles of file work. I can attempt to give
you an example in text and maybe a pic later
but no guarenteessss.
Some people do a lay out - measure and mark
a blade or liner or back then file. I do it
by eyeball and don't worry if somebody gets
out the dial calipers it's handmade. If somebody demands exactly and precisly and to
the thousnds. I send them elsewhere. Don't get me wrong with practice you can get very
presice but not perfect doing it with a file
by hand.
A pattern you can practice on is done with a
1/8" chain saw file and miniture round file.
Starting from where the guard would be move out the distance of the diameter of the file
(chain) and angled forward about45 deg. and
your hand about 30 deg. down. Use the end of
your thumb on your other hand against the file as a guide. File slowly and make a notch that goes about 3/4 of the way across
the back. Put the file across the back for
a gauge for moving the diameter of the file away from the edge of the notch you just filed and mark it by holding your gauge thumb
there and setting up your file the same as the first notch. Do the other side the same,
BUT make the notches oppose the opposite side. You can do one notch on one side and
then the other when you first start out if
you care to and it might be easier to guage.
After you have finsihed all the larger notches take the miniture file and go between
the larger notches and position it at right
angle to the blade and make a very small notch with the same downward angle. Very gently take off the sharp edges with fine
grit paper. You can do the same thing with
a round file and triangle file but with reversing the forward angle to the small triangle and the round file being perpenticular to the blade. This requires two triangle marks in between the round notches one forward and one back right next to the round notches and about 1'3 of the way into the edge. Practice is the
whole key before you start on a blade or do
spacers, liners or whatever. I don't know if this helped or not. I'll try to do some
pics later. I know everything is later.....
I sent pic attached to e-mail - not great but puts the script in perspective more.
goshawk
http://www.imt.net/~goshawk The race is not always to the swift, but he who hangs loose.
Don't walk in tradition just because it feels good!!!!!
[This message has been edited by goshawk (edited 03 August 1999).]
