- Nov 29, 2011
So started working on my first knife (kind of it is a kit knife). So figured I would try out a few different things. Did a real simple file pattern on the back of it (its a hunter style straight blade) kind of like a vine pattern without the extra cuts for the branches.
Was not thinking and started putting the handle on, sand blade side smooth, epoxy one side, drill holes, epoxy the other side, drill holes, install my brass pins. Peen them inplace then started sanding the handle.
This is where I realized that all my file work between the handle material and the blade had filled with epoxy.
Just wondering how you guys work around this. Ill post some pics tomorrow when I finish with the sanding job and touch up as necessary. Thanks.
