- Jan 2, 2006
Since my computer and I share a severe dislike for each other I do not spend much time on the internet, and have only recently discovered the Blade Forums.com. I found the discussions on file working , carving in steel and decoration in general of great interest, and would like to throw in some comments. Though I have used file working for many years, I realize that my methods are only one of the many ways to accomplish the same result, so here is the method that works for me. First I do all my design work on paper, I have not had much luck with letting the design “evolve” while working on the knife. I then transfer the design to the knife using a scriber. I only use carbide burs to provide a guide line for my files, since I don’t seem to be able to maintain truly smooth surfaces using burs. All my carving is accomplished with a file, many of which have been ground to include a safe edge. As much as possible I use straight needle files, often only the tip. From experience I know that I can polish any filed areas with a sanding stick and sand paper. All the decorative materials on my knives are hand fitted inlays, to a depth of approx. .070”. I never use overlays, since I feel they are a precarious method of installing decorations on a knife that will be regularly wiped with a cloth.
I would like to attach a photo of one of my latest knives showing file work I am currently experimenting with, but have no idea on how to accoplish this complicated task. I do have a web site ( www.wolfeknives.com), though sadly out of date it still has photographs of file worked knives.
Wolfgang Loerchner
Roger kindly posted the photo below. Thank you Roger!!
Wolfgang Loerchner
