- Dec 7, 2006
Trying to customize my first knife, a Case Hammerhead with some simple filework on the back spring. How to you get the first cut started with a file when working your pattern on the back spring? I am using a 3-corner file to make "V" notches spaced 3/16" apart. With the back spring securely clamped in the vise, and holding the file with the pointed end up, do you push the file downward or pull the file up to get the notch started? After I have my notches made on bothe sides of the back spring, I want to use a chain saw file to make "half moon" cuts between each V" notch. Again, how to you start the cut and keep the file centered between the two "V" notches? I already slipped with the chain saw file and screwed up the patterm. Any advice is appreciated.
