FileWork
I've been practicing filework, but my round file leaves really rough marks. What can I use to polish the metal?
I've been working on filing the vine design(on that cool tutorial page). I've done two attempts, and they aren't lookin too great. But if it's like anything else, I should better w/ practice.
You're right about practice, I probably have done two or three feet of that pattern and am just now beginning to figure it out. Persevere! It will start to fall into place.
As to getting the finish you want... First thing to consider is using a finer file. You can buy cheap Chinese files at flea markets, cheap enough to throw away when they go dull (as they will, fairly quickly). You can also buy good American files from hobby stores and the knife supply places. Also, Travers and MSC have great selections of files. Personally, I use the Chinese ones and throw them away frequently.
Be sure to keep your files clean while working. Any metal caught in the teeth will be very likely to leave deep grooves in your work. A good file card is cheap, find one at hardware stores or the knife suppliers.
I use a Dremel with Cratex tips to clean up most round filework. You can also wrap sandpaper around a dowel of the right size. You can polish filework with various hard felt wheels in the Dremel as well. This is preferable to a large wheel as it helps retain your sharp lines.
Hope some of this helps. Good luck, feel free to share your pictures!
Dave
There is a blue wheel that you can use to clean up file work. This is a rubber wheel that has a abrasive in it. It is intended to remove material and polish at the same time. I use them after using the cratex, sometimes just the blue wheel, thy are great to clean up solder joints. Get the knife edge wheels. You get them from Rio Grand 800 545 6566 www.riogrande.com Gib
Ps If you don't have there cataloge you need it.
You can also get little 3/4" sanding discs that fit on the same bit ass cut off wheels for a dremel. The ones I have are 220 and will felx a good deal, they're great for angling into tight spots.
The quickest way to clean up the rounds is to wrap a piece of sandpaper around the file you are using and smooth out the marks.Now me personaly I like to leave mine a little on the ruff side as it adds contrast between the filework and the polished blade.You can also just roll up some sand paper in a roll and smooth out the file marks also.
Bruce
