- Jan 21, 2005
Greetings! I was curious about filing bevels in by hand. What I intend to do is clamp the blade blank onto a similar sized piece of wood and then clamp the wood into a vice. I'm stumped from this point on. I plan to have the profile lines and centerline scribed in and plan to use a double cut bastard at first and then moving to a mill bastard when I approach the centerline.
When filing do I file down the length of the blade in succesive passes, or just file down an area section by section? Any tips y'all could lend a newbie are much appreciated.
Also, Wayne Goddard wrote about Norton SC/India oil benchstones in his books and I am considering using these as well. At what point would I use these? After the heat treating and tempering for the final profiling? How close to finished should a blade be before it goes off to the heat treat folks?
