Filing Guards....
blgoode
What type of file is best for filings guards and can I get them at sears?
Just looking for a couple to get me started......
Thats what I may look for at the flea market in Fla......see you turkeys next week :D
Cant wait to get back and get my hands duuurty!!
I use needle files for the most part, pluss a couple of modified regular files that I ground one side or the other off of to get in the slot, pluss a round file that I ground flats on either side to go lenthwise.
I bought most of mine at Sears, just keep the reciet and when you break or wear them out they will replace them.
Cant' have to many files, but a set of needle files will get you started.
Brownells has a selection of files that is just too cool for knifework. Habilis makes a set, too, that is intermediate sized, that I use a lot. They're in one of the knifemakers' catalogs, either Koval or Sheffield. I have probably 2-300 files, most of which I actually use, many of which I've modified for specisic tasks, ground a clean flat on, bent, etc.
Can't have enough files!!! The newest acquisition was a set of diamond riffle files I got from a carving place. Way cool! Tooltime!!
dlpierson...can you post the link again? I cant get it to work...Thanks for the help guys.
Try this one:
File
For some reason the board software chops it short if you paste in a long url and you also use the url as the displayed text.
Shalom,
Mark
Thanks......
Now I need to get to work on learning how to make the fittings.
That seems to be the hard part.....
Point files (showing my age here :rolleyes: ) are real handy for thin slots - most auto supply stores still carry them for us old dinosaurs.
I'll check for those also.........
I just need to get my guardless blades done ;)
Here's a two part approach:
Auger Bit File
If that doesn't work:
1. Go to MSC Home Page
2. Put "auger bit file" in the quick search box and press the go button.
3. It will display a set of controls to select the type of file you want to look at because it didn't understand the question :yawn:
4. That's OK, just select Auger Bit from the "Type" section widget it kindly put up. There's only one of them :D
Thanks guys. I plan on trying the guard thing before too long....now I need magnifing glasses :eek:
