Cutting the primary bevels on a few blades using a hastily lashed up ball joint based filing jig and I'm struggling to get the bevel right up to the tip...
The 2.5mm thick blades are to be stubby bushcraft ones, and will have around 3 1/2 inches of sharpened edge. The edge's 'belly' slopes gently along the length, then a fairly steep curve up to the tip - if I mark the cutting radius of the file on the clamping board, and set the majority of the edge on the same radius, the tip sits a good 1/2 inch further back and going for the same width of primary bevel surface as the rest of the blade (which leaves me about 0.5mm of un-sharp edge before HT time), the file crosses the midpoint completely leaving a finished edge with the bevel still a couple of mm short of where I want it.
Do I need to be re-clamping my blade with the curve and tip front and centre and file this part of the bevel separately to the main belly of the blade?
I've just used this jig to file and sand primary bevels on 12 single inside curved mushroom foraging blades, and 8 double inside curved (one on main body of blade, another short scalloped edge towards the tip) mushroom blades - it was tricky as the radius the jig cuts at is opposite the radius of the inside curve of the blades, but I made it work. I was expecting these little blades to be easier though, but so far I'm a little foxed...
Cheers for any helpful advice folks - I've already tried to search out the info but it's a bit like the needle and haystack scenario, only it's the needle I'm looking for amongst a load of very similar looking, but ultimately dissimilar needles. ',;~}~
Shaun.
Shaun.
