- Feb 26, 2016
Its been from a while back, but I wanted to finally post the first fillet knives I made after consulting some of you guys on here. After making these and gaining some experience on the matter, I'm going to change the design a bit to suit my local clientele; a little more width at the base of the blade and a more obtuse point. These are AEB-L. I grind short .095 pretty often but initially I found grinding a long thin piece of .082 to be pretty challenging. I began the first one using a jig after getting a little frustrated free-handing it. The second one was .100 so I was more confidant free-handing it, then by the third one (back to .082) it felt like no problem. I ground the taper directly into the first blank, but ultimately found it was easier to get the desired taper by just doing it as a part of the normal grinding process, just making subtle adjustments along the way. I sorted out AEB-L warping by implementing a stress relief (should have done it the first time) clamped between steel bars, and keeping it between the quench plates through out HT. Anyway, thanks for your input during the initial inquiry guys.
