- Apr 27, 2009
I am making my first fillet knife for a guy at work. I used .095 stock from Aldo and quenched in canola. I tempered at 345 in my wife's convection oven. Will that be to hard?
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Sorry I totally forgot to list the steel. It's 15N20. 2 or 3 (I forget) normalizing cycles and a 3 min soak. 345 temper because the convection settings on our oven do some wierd math. It's a FFG 8" blade with distle taper the full length.Did you use mystery steel?
You most likely will be just fine. It all depends on how well you hit the sweet spot during hardening. 15n20 will hit 66rc+ if not allowed to over heat. This requires a heat treat oven and testing to find the "perfect" temp. But generally speaking I would expect a normal Heat treat to hit 64-65rc easily if done right. I find a 300° temper with a 66RC blade will drop it to 63RC. After that it seams like every increase in temp by 25° will drop 1RC. So if I had to guess I would say you are in the range of 60-61. Which is more then fine for a fillet knife.
15n20 is very tough and a lovely steel to work with. It can take a very thin edge and still handle some crazy abuse. I would like to see your blade. When I make fillet knives from 15n20 I also do a full flat grind but I take the bevels down to a zero thickness edge. Then a light zip across a fine belt with the edge down to create a burr. After a quick strop on leather or a buffing wheel it's laser sharp.
