In order to get the flex you want you have to balance out the thickness with the width and length of the blade. The length of the blade depends on what kind/size fish you or your customer want to fillet. If we are talking salmon or halibut i would go at least 14 inches in over all length. Once you get the length nailed down design the blade, again, for the fish. Form follows function, always. Consider the rib bone thickness. If the knife blade is too thin and narrow it will tend to "whip around" or "wander" due to twisting and flexing and not go where you intend it too. First figure the length, then the width and shape of the blade, then take it down in thinness. Also consider need for stiffness for cutting "steaks". Again, if it is too whippy, it will be a pain. The wider the blade, the less whippy it will be, but it won't "cut the curves" as well. If the blade is not thin/flexible enough, it may not "flex flat" as easy when cutting off the skin. Also, each steel has different flex characteristics. In other words, same dimensions, different flex.
