- Dec 18, 2009
I've thought about how to find out the angles of your blades. Since a lot of companies do not put their blade angles on their info, I've developed a trigonomic system of measuring blade angles.
Materials:
-Calipers (precision digital)
-Fine ruler
-Calculator (scientific or higher)
Measure the thickness of the edge from the relief cut, then measure the height of the relief cut from the edge.
(-)=Theta
The equation should be Tangent(-)= (1/2thickness)/relief cut height)
So what you should punch in is...
Tan^-1 (inverse of tan)*((1/2thickness)/relief cut height))=(-)
(-)*2 should give you the edge angle.
So for example...
My cold steel kukri machete (because it's easy) has a 3mm thickness and a relief cut that is 5mm high.
Therefore my equation should be...
Tan(-)= 1.5mm/5mm
Therefore what I should punch in is
Tan^-1*(1.5/5mm)=(-)
(-)=16.6 degrees
2(-)=33 degrees
Therefore I should sharpen on my sharpmaker or lanskey (in theory) on the 30 degree setting for this knife.
If you have a true full flat ground knife with no bevel it becomes much easier as you just measure the full thickness of the knife and the full width of it and input it into the same equation. This equation will not work with convex grinds with no bevel in them. It does not matter which units you use (mm, meters, centimeters, inches, ect.) as the units will cancel each other out.
Hope this helps.
P.S: This will also help in re-profiling if your sending it out to a heavy duty sharpener with stone wheels or a belt sander or even if your doing it yourself. Just halve the value of what angle you want and punch it back into the equation solving for the height of how high you want your relief cut to be.
So if I wanted a 22 degree angle I would go...
Tan(11)=(1.5mm/x)
x=1.5mm/Tan(11)
x=7.7mm
So I would need to move that relief cut about 2.5mm up to get a 22 degree edge.
Materials:
-Fine ruler
(-)=Theta
So for example...
Tan(-)= 1.5mm/5mm
(-)=16.6 degrees
2(-)=33 degrees
Hope this helps.
Tan(11)=(1.5mm/x)
x=1.5mm/Tan(11)
x=7.7mm
