I can’t remember how many LPI the checkering file was that we used, but when I was at John Doyle’s shop, we used a piece of sand paper over a razor blade to get down into the grooves after heat treat. A little tedious, but it worked.
Jeremy
The wire wheel I have navman is too dense, sort of twisted tufts.try a wire wheel, but be careful!
Hello John.Use whatever tool you used to make the lines in the first place.
Good day Hengelo.Or leave the jimping darker as an accent.
You may use a sharp needle file to clean up
Thanks Armin.What about sandblasting?
Thanks. I will try a jewelers saw blade.I'm a bit confused.
I have both 20 and 50 TPI files. I am using a Jewelers saw to clean and make a slight undercut for each fine groove of the 50 TPI. It's tedious but necessary to get some inlayed wire to stick.
For 20 TPI I can easily clean it with folded sandpaper. Maybe you need a finer grit to fold flatter.
Thanks, I have a little slip sheath for it, but don't carry it too often. (it was the right size to use up a scrap of 3V...)You are absolutely correct. Not my best effort on this particular blade. For one thing, the jimping is not full depth or even. It is not terrible, but the photo makes it look way horrible.
Also, the photo makes the groves look larger than they are. I can just barely insert my finger nail in to them. The decarb/scale is too hard to just scrape out, even using a rough edged knife blade.
Steel is O1, hardened in an atmosphere controlled oven, cryo treated and then tempered to 59-60.
I'm thinking the jeweler's abrasive saw might be the ticket.
Thanks for the input Richard and that's a cute lapel dagger. Do you carry it?
Scott
If you just want the scale removed I would etch in ferric or vinegar until it loosens and scrub it out with a wire brush. If you want the grooves shiny then a diamond needle file is probably what I would use, after doing the etch and scrub.
