I made my first pancake sheath roughly following or at least, inspired by, Horsewright's excellent tutorial in the How To sticky at the top of this forum. This is for my personal EDC knife. It isn't nearly as neat and professional as his, but then, sheathmaking is just something I'm learning. Standard fold over belt sheaths are simple. This pancake sheath was a bit more "involved" let's say. The greatest challenge, and one I almost messed up, was the little retention hump inside. It was sort of a guess and I guessed too small. I ended up having to literally reach in with a blade and cut it back. Too much material needed removing to use a round file as suggested. I would guess I'm within a millimeter of the stitching. So I learned something for next time. Anyway, my thanks to Horsewright.
[/URL][/IMG]
And all that to ask a question...
I did dye my sheath and in the past I've used resolene for the final finish, then added some Obenauf's for waterproofing, letting it set overnight. The problem with that is, the Obenaufs seems to dissolve the dye somewhat and will wipe off rather heavily on a cloth. It has to be wiped down aggressively with a cloth before using, to remove this residue else it will wipe off on your clothes. I almost feel as though I'm wiping off the Obenaufs. So why do I use Resolene and what purpose does it serve? I don't know other than it is the "final protective finish" you put on leather as suggested by a lot of tutorials/instructions, etc. I know some people DON'T use it.
So after the dye, is it okay to add some Obenaufs, rub in and call it good, eliminating the Resolene altogether? Or, add the Resolene AFTER the Obenaufs?
