Finished my AD sheath
foxyrick
British Pork
Thanks for those who suggested the colour - Black was definitely the right choice!
Here's the finished (nearly) article. For some reason, the dye that got on the stud took the colour off it(!) but it was my last one so I've ordered some more. I'll replace it and polish it up a bit more when the new studs arrive.
For my first leather sheath, if I do say so myself, it's not too bad at all!
Before:
After:
Beautiful sheath for an AD. :thumbup: Just a comment, what if you trimmed off just a touch of the strap overhang. Would you consider making more of the same?
That is a very nice sheath; functional and well made! It seems though! Personnaly, I would leave the strap like that; easier to operate with gloves.
Very nice work! That strap depends on how you are using the knife. It could stay or go, if an orderer requests no, then so be it, if they want it then ok too! Congrats!
Thanks for the kind comments.
I left the strap long on the principle that if I found it too long, I could shorten it, but not vice versa. The down side to it is that it could more easily catch on things. I'll have to field test it for a while to know. So far I like it the way it is - it does make it easier to open as the stud is very strong.
Nice work! That looks great. I hope it's as functional as it is good looking. :thumbup:
Making a couple of leather sheaths is on my list of things to do over the winter. I need to order up some supplies from Tandy.....
Stay sharp,
desmobob
Very nice! I imagine there is a great deal of satisfaction in making your own...
I hear its difficult to sew leather. Does one have to make the holes first and then sew the thread through?
It is very satisfying, it also means I can get it just the way I want without spending too much money.
The stitching's not so hard, but you do have to make holes first...
I drill the holes for the leather, after clamping the edges together. A lot of people glue the edges as well. I used a 0.8mm drill bit in a modelmaker's vertical drill press that I used to use for drilling circuit boards.
The other way (more traditional) is to push an awl through the leather to make the initial hole. This is arguably better as it doesn't remove leather, just pushes it aside. So when the stitches are in, the leather can close up again, sealing the hole. It's much harder to do with thick lumps of leather though, and certainly harder when you don't have an awl!
Either way, it's best to mark the stitch points first with either a stitch iron or a stitch wheel. The stitch wheel is the only leather tool I have apart from the needles. The iron has a row of pins in a line so is great for straight lines. The wheel is a toothed wheel on a handle that you run along the line you want to stitch. Then you make the holes where the marks in the leather are.
It's also best to groove along the stitch line, so that the stitches are recessed. There's a special tool for this but I used a screwdriver.
The holes are still quite narrow so I used a pair of pliers to push and pull the needles through the holes. I use two needles, one on either end of a single piece of thread, and push each one through each hole, from opposite directions, so you get a stitch on each side.
The hardest part is threading the darn needles! The thread is quite thick and multi-strand - it really doesn't want to go through that little hole. My technique? Put a bit of glue on some paper, fold it, and squeeze the end of the thread through the glue. It seals the ends of the strands and leaves a thin tail that you can get through the eye. The only alternative I've found is to ask my wife to do it!
I melt the end of the thread a little ,squish it while its warm then cut it to a point ,works well.
Richard
Sorry Fox, I call bull S@#$.
That looks WAY,WAY too good to be your first sheath!!
That is some really good work. I'd proudly wear that one to town!:thumbup::thumbup:
lol - you're right, it's not my first sheath, it's my second, but it is my first leather one!
My first sheath was made from a recycled laptop bag for my BATAC. A bit rough looking but quite functional.
Awesome design and very well executed! :thumbup: I think you are right about the retention strap, you can always cut some off but you can't put any back on.
The only suggestion suggestion I would make would be purely cosmetic. Most leather workers use an edger to knock the corners off the edges.
This sheath is leaps and bounds above how my first one came out!!:cool:
Fantastic first sheath. I look forward to seeing what you make nest
Congrats. Working Leather can be a great deal of fun and satisfaction.
